Page 1 of 2 12 LastLast
Results 1 to 10 of 12
  1. #1
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Default Atv harrow
    I want to build a harrow for behind my atv (kodiak 450). Would a harrow work for burying seed (I would be growing wheat), in other words, would it seed deep enough? How big of harrow would the quad pull RELATIVELY EASY ?
    Thanks for the input
  2. #2
    Join Date
    Jan 2010
    Posts
    536
    KS.
    Case 1845C skidsteer
    Default Re: Atv harrow
    Might want to take a look at the chain harrow. The chain harrow has 3 seetings. Teeth pointed forward or vertical is deepest setting. Teeth pointed backward is itermediate setting. Upside down with teeth pointed up is the shallow setting. I use the shallow when working in broadcast seed like wheat. These chain harrows do pick up trash if your groud has a lot of debris. The chain harrow pulls easily and you could pull a 4 foot wide by 8 foot long easily. Biggest problem might be the transport. No probem with transport if you can pul it down your trails or roads.
  3. #3
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    Kubota B7800 with FEL
    I have a 4' wide x 7 1/2' long Fuerst chain harrow that my 350 Honda Rancher pulls easily. Some times I add weight to the top of this harrow and the Honda doesn't have a problem with it. I use it for breaking up horse manure and smoothing disked ground for food plots.
    http://www.servis-rhino.com/media/do...products_1.pdf
    I used to do the Hokey Pokey but I turned myself around.
  4. #4
    Elite Member bullbreaker's Avatar
    Join Date
    Mar 2009
    Posts
    2,930
    SW FLA
    1/3 PARTNERSHIP IN BOTA 7060 (PLANT NURSERY OPERATION) SOLD MY PERSONAL L3400 DT BOTA
    Heres info and spec's 2 build on one model.
    Worksaver ATV Seeder/Spreader
    http://worksaver.com/product/atvgt.html
    Boone
    2 CHRONICLES 7 : 14 (KJV)
  5. #5
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Thanks for the info,
    I have a set of spike toothed harrows, and a couple sets of diamond harrows, all i would have to do is put a hitch on them. Would these work, or not so much?
    My problem with the chain harrows is that there will be some straw, enough to plug them
  6. #6
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Atv harrow-image-jpg
    I have some similar to this. Would they work good for seeding?
  7. #7
    Gold Member
    Join Date
    May 2006
    Posts
    269
    tennessee
    kubota 95x zd331 rtvx1100, Polaris ranger xp900, m274a2 military mule
    Wheat seed really doesn't need to be buried, it will do fine on top of the worked soil. If you want to cover the seed cut a cedar limb or bush and drag behind your atv. I have used this method many times for food plots and it works well.
  8. #8
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Around here we seed cereals at about 1 1/2" deep, there's not enough moisture to broadcast it. I want to be able to simulate a field grown crop
  9. #9
    Gold Member
    Join Date
    May 2006
    Posts
    269
    tennessee
    How are you going to distribute the seed if you are not going to broadcast it?
  10. #10
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Sorry, I meant dont want to leave it on top, I have a spreader but I want to work it in
Similar Threads
  1. Replies: 12
    Last Post: 01-02-2013, 01:17 PM
  2. chain harrow for atv or tractor?
    By johntab in forum Attachments
    Last Post: 07-31-2011, 01:07 PM
  3. Drag harrow conversion to 3-pt harrow ???'s
    By jjmarotz in forum Attachments
    Last Post: 05-01-2009, 01:30 AM
  4. We got a new ATV
    By Tractors4u in forum ATVs & Utility Vehicles
    Last Post: 01-17-2005, 10:11 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
