ATV Sprayer
   / ATV Sprayer #1
Ted Summey
Germanton, NC
Kubota MX5100F IH McCormick Farmall 140, Massey Ferguson 135
I bought a 25 gallon spot sprayer a couple of years ago. It works well for my spraying around the yard. I've wanted an alternative to the 60 gallon sprayer for the tractor. So I picked up a kit to set up the spot sprayer as a broadcast sprayer. What I found was a funky arm that attaches to he hitch of the ATV. I decided to something different so I can spray my food plots.
I used an aluminum plate I had on hand. Drilled it to accept the broadcast spray nozzle and fabricated an attachment to the rear rack. The plate attaches with a wing nut and a tie wrap. It worked like a charm!
   / ATV Sprayer #2
Just put a boom sprayer on my Kodiak. Bought the kit for $60 on Amazon. Saw the kit that attaches to the hitch but it didn't impress me either. What I noticed with the boom sprayer is that even though the spec calls for a 7 foot wide coverage area, it really was more like 16 feet when I tested it. Fortunately, I can twist the nozzles so they spray to the inside (toward each other) and I can control the width and mitigate the misting with some precision. As you know, misting is bad, larger droplets are good.
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2016 CATERPILLAR 259D SKID STEER (A52705)
2016 CATERPILLAR...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
