Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Default Is this possible?
    I have a hand sprayer and I want to know if I would be able to take the hand wand off and make a small boom for it (only about 4' wide) and use it behind a quad? (Mount it up on the back of the quad, or on a small trailer. If on a trailer i would put a long handle on it so i could still pump it easily) I know the arm would get tired, but I'm cheap and just want to know if this is possible?
  2. #2
    Elite Member whistlepig's Avatar
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    Kubota B7800 with FEL
    I used to do the Hokey Pokey but I turned myself around.
  3. #3
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Default Re: Is this possible?
    Is this possible?-image-jpg
    Somethin' like this
  4. #4
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    I'm sure that this is possible. I would think that you would be doing a good deal of hand pumping. Using one hand for the throttle and brake and pumping with the other hand would make steering the ATV interesting.
  5. #5
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Excersize. Lol
  6. #6
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    I have a 15 gallon 12 volt sprayer on my ATV that I use to spray my fence lines. On my Polaris the throttle is on the right hand grip and the brake is on the left hand grip. And I gotta steer with something. Factor in another hand to operate the sprayer lever on my spray wand. Doing all of this and trying to pump a hand sprayer would probably turn me into warm jello. I can do some multi-tasking. But not that much.
  7. #7
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    I probably won't spray a large area, so I could foot it i suppose
  8. #8
    Join Date
    Jan 2009
    Posts
    4,267
    Preble County, Ohio
    The small 12 volt sprayers aren't all that expensive. You can cover a very large area with a hand wand. I have used mine for food plots. I don't have a boom. Mine is over twelve years old and except for replacing an occasional sprayer handle it has been trouble free. It was money well spent for me.
  9. #9
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
  10. #10
    Gold Member Smallplot's Avatar
    Join Date
    Sep 2011
    Posts
    386
    Pike County Illinois
    1974 IH 1066, 1969 IH 756/FEL, and 2011 TYM T603 Cab/FEL
    Another consideration is adding nozzles will drastically effect how much pumping action is needed to give a consistent flow. Add a second nozzle it will take 2 times the amount of pumping.
    Dan,
    www.pikecountyfoodplots.com
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
