Results 1 to 5 of 5
  1. #1
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Default Should I worry???
    Should I worry???-image-jpgI'm thinking of buying this disc, its 33" wide and the discs aren't at a very aggressive angle. Should I worry about killing my quad? (Burning off the belt, ENGINE OVERHEATING, etc)
    How heavy does this disc pull compared to a harrow? (How big of spike tooth harrow pulls about the same as the disc?)
    Or will I loose traction way before then?
  2. #2
    Elite Member nybirdman's Avatar
    Join Date
    Feb 2009
    Posts
    3,886
    north of upstate ny
    Kubota L4240 HSTC,L3000DT
    Default Re: Should I worry???
    Sorry but those are about useless.Use your tractor?
  3. #3
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Have no tractors under 100 horse
    Useless how? Just don't go down?
    As far as not going down, I can find a way to add weight to it
  4. #4
    Join Date
    Aug 2012
    Posts
    174
    Plymouth, mn
    None yet
    Default
    Looks like the king cutter I have. For breaking ground it's useless even with weight added. I pulled it with my Polaris 800 and it handed it well. Transmission got very hot but I never over heated or burned out a belt. Yes it wore the belt a lot faster and was **** on nearly every part of the atv driveline. It did over heat a friends Mule 610 (400cc).
    The only way I could get it to cut was to rearrange the discs and do circles.
    After a couple years of struggling I gave up on the disc and using an atv for a y serious work and bought a CUT last year. I'd be happy to sell you my atv disc so I can afford a real 3pt disc.
  5. #5
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Got one last week. I have 140lbs of weight on and im quite happy with it(im in sand so that probably makes it alot easier going down) will break up grass after a few passes. My quad pulls it quite easy, easier than i thought it would!
Similar Threads
  1. Bucket is not level ... Should I worry?
    By easygo in forum Kubota Owning/Operating
    Last Post: 04-18-2008, 10:37 AM
  2. biggest worry?
    By huckie in forum Kubota Owning/Operating
    Last Post: 06-18-2007, 12:01 AM
  3. to worry or not to worry
    By tractorshawn in forum Massey Ferguson Owning/Operating
    Last Post: 07-05-2006, 12:06 AM
  4. Tires Worry about tires
    By Anonymous Poster in forum Kubota Owning/Operating
    Last Post: 05-23-2000, 11:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
