Results 1 to 10 of 10
  1. #1
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Default My mini seeder
    Here's my seeder that I built (partially anyway) Its only about 24" working width, so it won't cover a huge area fast. But I'm gonna use it and hope for the best!
    My mini seeder-image-jpgMy mini seeder-image-jpg
    Thanks for looking!
  2. #2
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Default Re: My mini seeder
    See anything i could/should improve/change?
  3. #3
    Veteran Member CliffordK's Avatar
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    Toro D200, Ford 1715, International 884,
    Interesting design. I'm trying to figure out what your plans are though.
    I assume the drop fertilizer spreader will tend to spread seeds evenly. Which isn't a problem if that is desired, for grass or a grain.
    Your baler/rake tines scratch the dirt in rows, but don't really force the seeds into a row, nor cover very many of them.
    If you wish to drop the seeds evenly, then cover them slightly, you might consider dragging something behind such as a 4x4, chunk of steel, some chain, fencing, or such.
    It is being used on tilled ground?
    I saw this on craigslist.
    5' Vineyard Seed Drill
    It is on the West Coast, but it may give you some ideas. Old grain drills are cheap, although, not always functional. This one apparently was cut in half for use in an orchard, but may be a more manageable size for a small plot.
  4. #4
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Yes, it will be used on tilled ground.
    It will work the same as broadcasting seed then harrowing it in. I just made it into one pass. If the small tines i have on there don't bury seed enough (which I am kinda concerned about) I will get heavier tines to put on
  5. #5
    Join Date
    Mar 2013
    Posts
    1,202
    Eugene, Oregon
    I just don't think it will harrow the seeds in.
    It never hurts to try a test.
    But, dragging something behind it, or perhaps putting multiple rows on your "harrow" would likely do better at covering the seeds.
  6. #6
    Join Date
    Jan 2001
    Posts
    1,381
    Alberta
    Kubota B2410 with turfs
    I'd say you will need heavier tines, or as CliffordK indicated, just drag something behind like a piece of chainlink fence or something.
    Kevin
  7. #7
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,491
    Somewhere north of Roseau, MN
    Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
    Unfortunately, I don't have anything useful to add, but I like the way you're thinking! Make use of what you have. I'll be very interested in how this develops over time.
    Joe
    Joe
    Fordson Major Diesel: Case 3-bottom Trip Plow, Case 12' Trip Field Cultivator, Kewanee 130 Disc, John Deere 1209 Mower Conditioner, John Deere 594LW Side Delivery Rake, New Holland Hayliner 273 Baler, 18' Spike-Tooth Harrow
    Ford 1510: Du-Al 105 Loader, "The Thumb" Grapple, Bush Hog RBC60 Rear Blade, Woods HC54 Rotary Cutter, Tarter 5' Heavy-Duty Hinge Back Box Blade, Buhler Farm King Y600 Snowblower
  8. #8
    Join Date
    Mar 2013
    Posts
    101
    Southwest sk
    New holland 9682
    Today I tried the harrow itself in some soft dirt, not dropping seeds. It seems like it turns over the dirt well. I think it will be good for grass/alfalfa and good enough for rye. Which is what I know I'll be seeding a decent sized area into. So I'll try it as it is and modify it as needed
  9. #9
    Gold Member Wyobuckaroo's Avatar
    Join Date
    Nov 2010
    Posts
    389
    Frozen bush of NW BC CA
    John Deere 2032
    Here is a thought...... Use some dry white sand in your seeder for a test run and see how it works.
    After all this is for food plots, not a cash crop.
    Good luck
  10. #10
    Join Date
    Jan 2007
    Posts
    1,419
    Creal Springs, IL
    Kubota M7040, F3680, Mule Pro Fxt
    If your doing this on tilled ground, drag a section of fence behind it.
Similar Threads
  1. Seeder, Over seeder , Fetilize Spreader
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 10-13-2013, 07:17 AM
  2. Over seeder or Primary Seeder???
    By ChuckVierthaler in forum Attachments
    Last Post: 10-04-2012, 10:01 PM
  3. Seeder, Over seeder, Roller, Aerator, Fertilize spreader
    Last Post: 04-09-2010, 06:20 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
