Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2005
    Posts
    769
    SE Connecticut
    JD 5325; Landini Mistral 50
    Default Seeder Questions
    I'm searching for a seeder that will do alternating cover crops of grass and legumes with the possibility of wildflowers later on 4-5 ft strips 800 ft long over 5 acres. When I look at the used seeder market I see seeders that have a large box without agitator. How important is having an agitator? Also for the legumes is seeding from a larger box present any difficulties? I'm a newbie when it comes to seeders but I understand that the smaller legume seed box that meters lower rates is preferred with seeders but I rarely see these on the used market in the 4-5 ft width hence my question about doing legume seeding from larger box...Thank you, Gary
  2. #2
    Gold Member
    Join Date
    Feb 2012
    Posts
    355
    Brandenburg ky
    2013 john deere 5075E and others
    Default Re: Seeder Questions
    Here's the deal with "spinner" type seeders. Seed like orchardgrass, fescue, ryegrass, etc will "bridge" in the hopper and not feed out consistintly without a agitater or stirrer because they are "fluffy". Small seed like clover, alfalfa. turnips, only need a few pounds per acre so a seeder with a very small setting is needed. Resist the temptation to sow different seed types/sizes together. I.E, orchardgrass and clover. The different densities make them spread at differant widths, clover make go to 20ft and orchardgrass may go only 12-15ft. You get streaks. Drill type seeders have multiple seed boxes for planting more than one seed size at the same time. Some may even have "native grass boxes" Another advantage of a "drill" type is more accurate seed depth placement, and another in less passes over the field. But they are more expensive and take a larger tractor to pull them. I have used a 10ft Tye brand and a 10ft Great Plains brand on several 100 acres of pasture and hay with good success. Don't turn with the drill down(in the ground), many parts will be needed as a result.
  3. #3
    Gold Member Smallplot's Avatar
    Join Date
    Sep 2011
    Posts
    386
    Pike County Illinois
    1974 IH 1066, 1969 IH 756/FEL, and 2011 TYM T603 Cab/FEL
    Quote Originally Posted by Haoleguy View Post
    What seeds are you actually planting? There are many differences between grass seeds by species and Legume seeds by species. From your description sounds like you are talking about a drill am I correct?
    Dan,
    www.pikecountyfoodplots.com
  4. #4
    Join Date
    Apr 2005
    Posts
    769
    SE Connecticut
    Quote Originally Posted by Smallplot View Post
    This Fall I would be planting winter rye with some tillage radish in some areas. Other areas would receive hard fescues. Might do some buckwheat next summer in areas going through alternating cover crops to build soil organic matter and crowd out weeds. Not fully decided on legumes but definitely crimson clover and hairy vetch. In terms of seeders I was thinking of a cup metered drop seeder like a Land Pride APS 15 series or a Kasco Vari-Slice which would spread coverage more than a drill would. Drills are hard to find in an overall width of 60 inches which is my tight requirement.......Gary
  5. #5
    Veteran Member kneedeep's Avatar
    Join Date
    Apr 2012
    Posts
    1,079
    Central AL & MS Delta
    Mahindra 3510 and Mahindra 8560 Cab 4WD
    Be on the lookout for a Taylor Pasture Dream or Pasture Dream Seeder. These old units will plant anything no-till into existing pastures or food plots.
    Attachment 399122Attachment 399123
    You can double pass plant on a diagonal ( 20" row spacing)
    Seeder Questions-10-31-114-2-jpgSeeder Questions-20141017_153100-jpg
    They can be modified with a hydraulic cylinder to operate the seed gates
    Seeder Questions-seed-gate-jpgSeeder Questions-seed-gate-1-jpg
    Attached Thumbnails Attached Thumbnails Seeder Questions-20141017_080043-jpg
    PROUD AIR FORCE DAD
  6. #6
    Advertiser sweettractors's Avatar
    Join Date
    Jul 2003
    Posts
    7,645
    Central Kentucky
    JD 6403 CHA-JD 3130 CHA
    The link below shows many seeding/renovating tools that we have in stock today. Ken Sweet
    items in store on eBay!
    http://www.sweetfarms.com/
    Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
    Shipping Facility
    1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
    Ken Sweet sweet@scrtc.com
    Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
    The Northeast shipping corridor is a little more expensive.
  7. #7
    Join Date
    Apr 2012
    Posts
    1,079
    First 2 pic didn't post of the planter I have. If you can find one they usually are less than $1K (I paid $350 for mine w/o lid and seed gate mechanism worn out)
    Seeder Questions-20141011_140123-jpgSeeder Questions-mfdc0043-jpgSeeder Questions-taylor-planter-2-jpgSeeder Questions-cam00087-jpg
    Not mine but shows the mechanical seed gate that is usually worn out
    Seeder Questions-untitled-png
    PROUD AIR FORCE DAD
Similar Threads
  1. Seeder, Over seeder , Fetilize Spreader
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 10-13-2013, 06:17 AM
  2. Questions about my seeder
    By TED20MAN in forum Attachments
    Last Post: 05-22-2013, 11:04 AM
  3. Over seeder or Primary Seeder???
    By ChuckVierthaler in forum Attachments
    Last Post: 10-04-2012, 09:01 PM
  4. Seeder, Over seeder, Roller, Aerator, Fertilize spreader
    Last Post: 04-09-2010, 05:20 PM
  5. Seeders 3pt PTO Seeder
    By tkcomer in forum Attachments
    Last Post: 10-09-2005, 08:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
