Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Jul 2007
    Posts
    11
    Smile 1944 9N ford tractor
    The engine looses power after running for about an hour. I only use it for cutting grass with a 5' brush hog attached.The last time it happened, I noticed gas dripping from the bottom of the carberator.Could I be getting a vapor lock from the heat by or near the gas line? I would appreciate any advive. Thank you.
  2. #2
    New Member
    Join Date
    Aug 2009
    Posts
    16
    Default Re: 1944 9N ford tractor
    do a comp. check hot and cold if that checks good overhall carb and do a good tune up.
  3. #3
    Elite Member mostly_gas's Avatar
    Join Date
    Sep 2009
    Posts
    3,873
    Texas
    in-between tractors
    Also check radiator cooling fins for buildup and fan belt tension for cooling fan speed.
  4. #4
    Gold Member
    Join Date
    Jun 2009
    Posts
    274
    Sumner county, TN
    Check your ignition coil. A lot of time they will get hot and start to act up.
  5. #5
    Join Date
    Nov 2005
    Posts
    1,166
    If your tractor is a 1944, then it would be a 2n (1939-1941 = 9n, 1942-1947 = 2n, 1948-1952 = 8n) Lots of folks get mixed up about this because there aint much difference between a 2n and 9n. Ford didnt build many tractors in 1944 due to military production requirements, and because of that, your tractor may have some collector value. In general, the 8n's are worth a good bit more because they have many improvements over the 9n's/2n's, especially the 1951's and 1952's. I would check the compression of your tractor, as I suspect worn valves as your problem.
  6. #6
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    gas dripping from a carb is a sign of flooding and or stuck float or dirty float valve.. not vapor lock. Vapor lock would be the absence of fuel.. not the overabundance of fuel.
    when she feel weak.. check spark
    she still 6v?
    got the oem coil and ballast resistor?
    soundguy
  7. #7
    New Member
    Join Date
    Jul 2007
    Posts
    11
    Hey Soundguy, How are you doing? Yes it's still 6volt systemand I think it's the oem coil and resistor. What's the best way to check the spark? Thank's.
  8. #8
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    check spark by pulling a wire and plugging in a spare plug with the gap opened to 3/16" and grounded to the block. check each wire.
    soundguy
Similar Threads
  1. Replies: 2
    Last Post: 07-06-2009, 09:00 AM
  2. Problem with Ford 3000 tractor..
    By jnixon in forum New Holland Owning/Operating
    Last Post: 07-07-2007, 03:43 AM
  3. GC-2310 Update -- The latest and greatest
    By Mike_in_Okla in forum Massey Ferguson Owning/Operating
    Last Post: 03-19-2006, 01:51 AM
  4. Which Tractor to Buy
    By captkel in forum Buying/Pricing/Comparisons
    Last Post: 07-25-2005, 04:57 PM
  5. eBay/Craigslist ebay item
    By djg in forum Yanmar
    Last Post: 06-24-2005, 08:37 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
