Results 1 to 7 of 7
  1. #1
    Member
    Join Date
    Apr 2011
    Posts
    27
    piedmont nc
    Default 62-63 ford 2000-w/selectaspeed-good-bad -ugly?
    guy at work says he has thistractor wondering what problems to look for?????????????
  2. #2
    LD1
    LD1 is offline
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,469
    Central Ohio
    Kubota l3400
    Default Re: 62-63 ford 2000-w/selectaspeed-good-bad -ugly?
    Quote Originally Posted by deerfarmer View Post
    Select-o-speed = bad and ugly
    Personally I'd shy away
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  3. #3
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,066
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    if the unit is running, and moves in all forward 10 gears and 2 reverse gears, hot or cold. pto powers up, and shuts off ( may freewheel ).. and the machine is otherwise ok? then it's worth about 1/2 to 3/4's what a 4 speed would be worth.
    IE.. a 4 cyl 2000 sos won't usually get over 2000$ restored.. and 1500-1800 for a goodun max.. a 640/641/2000 4 cyl will hit mid 2500+/- in otherwise working condition.
    soundguy
  4. #4
    Member
    Join Date
    Apr 2011
    Posts
    27
    piedmont nc
    the man has spoken ! he just mentioned he would sell it today at work,really havnt questioned him about tranny or pto he did say it spun all the time but he only has pull inplements ,no tillers bushhog thanks again!
  5. #5
    Join Date
    Mar 2002
    Posts
    42,066
    Central florida
    no pto brake on them.. so it can spin, unloaded, when not engaged. hanging a brush mower on it is enough load that it should only spin witht he pto engasged. if it spins all the time there is an issue.. like acable adjustment, or pile dup clutches / warped discs.. etc.
    soundguy
  6. #6
    Gold Member
    Join Date
    Jan 2009
    Posts
    270
    southeastern west virginia
    1978 ford 3600, 1964 ford 4000 rowcrop
    in my teens i worked for a guy whom had a powermaster with a select-o-speed. i used it quite a lot. my take on select-o-speeds is they are an accident waiting to happen. i stay away from them. some people like em, i don't.
  7. #7
    Join Date
    Mar 2002
    Posts
    42,066
    Central florida
    they would be my least favorite tranny, . well.. maybee vieing for a 3 spd and a 6spd... the 4 spd, and 5 spd and 8spd fords are much higher on my list...
    soundguy
Similar Threads
  1. Adding FEL to '72 Ford 2000
    By herdfan in forum New Holland Owning/Operating
    Last Post: 02-04-2004, 04:07 AM
  2. Buying a Ford 2000
    By Anonymous Poster in forum New Holland Buying/Pricing
    Last Post: 07-06-2001, 01:23 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
