wmonroe
Elite Member
Had the 961 out brush hogging last week and the engine temp was starting to climb on me. The first hour or so was on fairly level ground but high, thick grass and the temps were normal, but the next couple hours were low grass (had brush hogged a couple weeks prior) but going/down some pretty good hills and the temp was starting to climb. It never got to the red end of the guage but it was definately up from normal. The tractor temp usually runs below the "12 o'clock" but when it was getting hot was about half way between the red and 12 o'clock.
I cleaned the radiator out really well last year and checked it and the grille and all was clear. I'm not sure if i could have a thermostat that is getting sticky and not opening consistent or if the water pump might be shot and not moving enough water. It just seems to me that something can't be right as the tractor wasn't working that hard but was almost to the point i needed to stop and let it cool.
Any ideas?
Any ideas?
