Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    New Member
    Join Date
    Oct 2011
    Posts
    16
    Ford 8n
    Default 1949 Ford 8N
    Hi,
    Just a quick introduction, my name is Kyle and I just got my first tractor, a 1949 Ford 8n. I included some pictures and I will probably have lots of questions along the way. My first question is when I took off the PTO drive cap about 1/3cup of oil came out, does this mean the PTO seal is shot or is it over filled?
    Thanks!
    Attached Thumbnails Attached Thumbnails 1949 Ford 8N-tractor-face-7-7-jpg   1949 Ford 8N-tractor-face-1-7-jpg   1949 Ford 8N-tractor-face-6-7-jpg   1949 Ford 8N-tractor-2-7-jpg
  2. #2
    New Member
    Join Date
    Oct 2011
    Posts
    16
    Ford 8n
    Default Re: 1949 Ford 8N
    Oh and the serial number is 8N247305 off the upper block of the engine
  3. #3
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    Welcome to TBN.
    How much do you know about these old 8n's?? Are you familiar or a total rookie??
    I have a few questions, suggestions, and tid-bits of info for ya....
    First, I believe, based on your serial #, that it is a 1950 and NOT a 1949.
    It is obviously a old tractor that does need some attention, but for starters I'll tell you what I like about it.
    I like the adjustable 3PH arm that you can reach from the seat. This is a pretty desirable feature. It also has draft control, and appears to have decient rubber. Someone has also converted it to 12v.
    Now, the things that need attention, that seal, just keep an eye on it. Because the PTO needed to run for the hydraulics to work. So that PTO could have been left on all the time. And if the tractor was used ALOT, 1/3 cup of oil aint bad. But If you do replace it, it is a quick and easy fix.
    You also need to hook the air filter back up. You dont want to suck a bunch of dirt into that carb.
    Feel free to ask any questions. But I am curious if it has a sherman (another desirable feature). You didnt give us a pic of the tractor from that side. The sherman will have a "dog-leg" lever that is located on the side roughly between the clutch pedal and starter.
    And I didnt see if you mentioned, but I assume this tractor does run??
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    i see it has the original pto 1/18 shaft, not a replacement... also see a home made drawbar bracket, as well as a welded manifold.. non of wich are a immediate cause for concern as long as they work.
    the pto shaft seal is a 15 minute fix.
    if it is overfull, i'd worry more about oil on the brakes vs the pto.. I see the oem oil dipstick for the common sump rear end is gone and something else stuck in there.
    with machine off, grab pto shaft and see if it has in / out play or side to side play.
    if it has in / out play then it has a possible bad bearing, bad wear ring, slipped or broken circlip, or damaged bearing carrier.. if side to side play, then bad bearing. bad bearings will allow seals to hog out.. pto shafts with in / out play will eventually do 2 things, 1, mushroom the end of the shaft internally and make it hard to remove, 2, walk it out of engagement and eventually damage the pto shaft internal spline, and the sliding dog clutch.
    if none of those are an issue and it is just a leaky seal, again.. 15 minute fix, and about 17$ for a new seal and gasket.. drain rear end oil ( 5 gallons - refill with 90wt gl1 / 3 oil, or 80w90 oil meeting the gl4 / 5 / mti spec that states it is yellow metal safe, or any UTF fluid meeting the M2C134 spec. ).. 4 bolts and you snatcht he assy out, rmove rear circlip, tap pto external stub end down on a pice of wood on the ground, bearing carrier and seal fall off the pto shaft and bearing assy, drive old seal out, drive new seal in, ( 2 -5/8 socket makes a great seal driver ), reseat by greasing seal lip and setting pto lone end down on a piece of wood onthe ground, short end with bearing facing up, set bearing carrier and new seal on top, then tap down witht he shaft ontothe wood and the shaft will seat into the seal and carrier.. reinstal circlip, clean flanges up for gasket, slip back in with new gasket, bolt down, add oil.. etc.
    soundguy
  5. #5
    New Member
    Join Date
    Oct 2011
    Posts
    16
    Ford 8n
    So I am serious rookie when it comes to tractors. I have industrial mechanical experience, but no tractor knowledge. The man I purchased it from gave me the 2 min how to make it go forward and backward lecture and that's where it ends.
    Thanks for the advice so far. I tried to move the PTO around but it seemed very solid. If the shaft seal is an easy fix, I might just do it anyways. I am including a picture of the actual PTO output, will this work on new 3 point attachments or are there adapters?
    Kyle
    Attached Thumbnails Attached Thumbnails 1949 Ford 8N-pto-close-jpg
  6. #6
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    Quote Originally Posted by kvan View Post
    Kyle
    only way to tell is to messure the end of the pto shaft and see if it is 1 1/8 in or 1 3/8 in but they do make the adapter to go from the little shaft to the big shaft so it will work on all 540 spile equipment
  7. #7
    Join Date
    Apr 2008
    Posts
    18,049
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by whodat526 View Post
    Correct here
    Another option, while you have it appart, IF it is only the 1-1/8 shaft, you can buy an upgrade shaft that is the 1-3/8 for around $120 and you never have to fool around with adapters. We have broke and twisted off too many adapters on dads 8n to trust them. He upgraded shafts. This was mainly when using the tiller.
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #8
    Gold Member
    Join Date
    Jun 2004
    Posts
    275
    Niagara County, N.Y.
    Long 530, 2360, 360,2310, Ford 641, 8N, 2N
    The ID of that pto seal of the 1 1/8" shaft rides on a metal sleeve which is pressed onto the shaft. If their is a groove worn in the sleeve, where the seal rides, a new seal will still leak. I have also seen oil leak between the sleeve and the shaft. A new sleeve is available, but is a shrink fit to the shaft. If the sleeve does not have a groove, I'd replace the seal and bearing, and even the 2 circlips when disturbed. Make sure you add a little RTV on ID of housing for extra sealing when pressing seal into the housing. I like the idea of the 1 3/8" shaft replacement. Well worth the extra money and far less aggravation.
  9. #9
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    NO RTV is needed onthe bering carrier.. it has a gasket to seal it's flange to the rear housing.
    also.. new style pto shaft seals ride in a different spot than the old ones. so sometimes it is not a problem. seal ring replacement isn't too bad a job, or could even speedi sleave it if you wanted to.. or solder / braze it up and polish down. BTDT all work..
    on the adapters.. there is a sheetmetal bushing that only increases the OD, but not the length.. I don't like those. there is a better stub adapter that increases the lenght and OD to that of a standard shaft.. those are much sturdier.
    IMHO.. if the wear rin, bearing and seal are bad.. I'd get a new shaft assy.. etc.
    soundguy
  10. #10
    Elite Member jonyyuma's Avatar
    Join Date
    Sep 2010
    Posts
    2,972
    35 miles North of Memphis,TN
    kubota L3000dt, ford 8n1952
    Someone saved you from dragging off the exhaust or buying those tin mufflers for underneith...But do put an air cleaner on the carb, if it hasn't already eaten the piston rings?
    Okay, Legal disclaimer: Old but not senile, definitely do not have the answer to everything!
Similar Threads
  1. Restoring a 1950 Ford 8N
    By CDN8N in forum Ford Vintage Tractors
    Last Post: 02-18-2012, 11:36 PM
  2. Ford 8N Tractor
    By c5ken in forum Ford Vintage Tractors
    Last Post: 08-09-2011, 03:43 PM
  3. Ford 1700 Tractor OEM Paint Colors
    By Piper Pacer in forum New Holland Owning/Operating
    Last Post: 01-17-2011, 01:09 PM
  4. Ford 8N Carb Problem
    By stevegintn in forum Parts/Repairs
    Last Post: 09-25-2008, 11:17 PM
  5. Strangest Ford 8N I have ever seen
    By acs55812 in forum Attachments
    Last Post: 09-15-2008, 08:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
