Kirk-NJ
Gold Member
- Joined
- Sep 20, 2009
- Messages
- 411
Post some photos if you can.
Are the tracks ARPS or bombardier?
Kirk
Kirk
Nice job resurrecting a ten year old threadI run a log splitter off my 1954 NAA. I bought a Prince hydraulic pump that mounts on the tractor's PTO. Then I installed to fittings on my Ford's internal hydraulic tank (manual transmission area) and used that to supply the fluid. It would have been just as easy I suppose to by an external tank and mount it on the log splitter. My set up works very well.
Someone has to keep these old tractors and their threads alive.Nice job resurrecting a ten year old thread
Kirk
i hate to tell you this.. but the transmission is NOT the hyds sump on an naa.
the hyds sump on a NAA is SEPERATE from the trans, and SEPERATE from the rear end.
i hope you ar enot overfilling your trans and making for a leaking input shaft seal.. and I hope you are not destroying the trans by running plain hyd oil in it vs utf or gear oil.
lastly.. i hope you have suction filters on your log splitter so you are not sucking up metal particles from a gear case into your pto pump and valving.
Might pay to buy a manual for your machine so you can be more familiar with it.
I am pretty meticulous when it come to care of my equipment and maintenance. I have the original owners manual along service manuals. I may have mis described the description where I tapped into the tractor. I am definitely tapped into the hydraulic reservoir on the tractor, not the manual transmission fluid area..
just checking.. because you said hyd resv / tranny... and the two are not the same on a NAA..
