Results 1 to 4 of 4
  1. #1
    Member
    Join Date
    Jul 2011
    Posts
    31
    MF 231S
    Default 64 Fordson Super Dexta PTO Problem
    I am having trouble with my pto when I engage it for example bushhogging it will disengage on its own. It will stay engage until it get in some high grass unless i raise it up. If this is the problem, how do I adjust it. The tractor is a diesel 3 cylinder. I have tried to use a heavy spring to keep it in gear but now that wont work either. It will grind. I check the in/out play on the pto shaft. It is tight with no play. Is there a clutch that need adjusting. Have anyone had this problem and got it fix? IF so, is this a DIY job or shop fix? Do anyone have diagram of the internal parts?
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 64 Fordson Super Dexta PTO Problem
    i'm not up on the fordsons.. but if a mechanical sliding colar engaged pto clutch.....bad news.. if there is no in / out play, AND a bunji won't keep it engaged.. you are probably not looking at soemthing like a detent type fix. I'd be looking at the dog clutch..
  3. #3
    Member
    Join Date
    Jul 2011
    Posts
    31
    MF 231S
    Quote Originally Posted by Soundguy View Post
    Soundguy is their any repair manual that you know of that might be helpful in doing this project.
  4. #4
    Join Date
    Mar 2002
    Posts
    52,625
    Central florida
    i'd for sure get a shop service manual. Again.. I'm not up on the fordsons.. but a fo-201 covers the dexta I believe..
    http://www.ytmag.com/FO201_6413.htm
Similar Threads
  1. Fixed my 345 PTO bearing noise - DIY included
    By glader in forum John Deere Lawn & Garden
    Last Post: 12-02-2014, 10:45 PM
  2. !964 Fordson Super Dexta PTO Problem
    By fireman4074 in forum Parts/Repairs
    Last Post: 03-11-2012, 03:31 PM
  3. Power Steering Problem Not Solved
    By Alan L. in forum Kubota Owning/Operating
    Last Post: 03-31-2011, 07:35 PM
  4. JD 4000 series wheel bolts
    By Anonymous Poster in forum John Deere Owning/Operating
    Last Post: 04-13-2002, 11:56 AM
  5. Chain of command
    Last Post: 04-13-2002, 07:17 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
