Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Veteran Member sam5570's Avatar
    Join Date
    Jan 2012
    Posts
    1,429
    south west virginia
    new holland tn70
    Default 1953 jubilee
    a friend of mine is looking at a 53 jubilee he says everything looks ok and it sounds ok i no nothing about themis there any special things to look for and what do these tractors sellfor on average body looks good needs paint but not been abused
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 1953 jubilee
    1800-2500 tires and shape depending.
    make sure she has brakes, clutch works and 3pt works... especially when warm.
    hyds setup on the naa was only used for 2ys.. the 00 series obsoleted all the hyd parts on the naa pretty much.
    a cylindrical pump is a plus.. and old square vane pump is kinda a minus.
    otherwise.. all the usual stuff you look for.. make sure she shifts and don't jump out of gear going down hill. starts good.. charges.. takes throttle good. no oil in water.. no water in oil.. etc.
    she's got a 134ci gas engine / red tiger ohv.. etc.. about 32 pto hp or so.
    decent lil tractor.. I have the more rare 54 naa..
  3. #3
    Join Date
    Jan 2012
    Posts
    1,429
    south west virginia
    new holland tn70
    thanks soundguy for info like i said i know nothing about these tractors just a little before my time don't remember anyone around here having 1 the old 8n and massy 30 and stuff like that i know a little about again thanks for your help
  4. #4
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    keep asking.. someone here will answer. there are quite a few of us with old ford experience... someone will be here to help.
    rickb, whodat, jim.. me.. etc.. ( many others.. ).. jerry.. etc.. and the other jerry ( ultradog.. )
  5. #5
    New Member
    Join Date
    Apr 2012
    Posts
    2
    Birmingham, Alabama
    1953 Ford Jubilee
    On the subject of brakes, how do you know if the brakes are decent if you are buying? For example, my 1953 Jubilee stops on the flat ok, and for this reason, I assumed the brakes were ok when I got it. But, the brakes won't stop it on even a modest hill. I'm assuming the brakes need work, but are mechanical brakes that good anyway for going downhill? What should be expected for decent brakes on a tractor of this vintage and design?
  6. #6
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    Quote Originally Posted by chae5036 View Post
    the brakes should hold the tractor on a slop how i check the breaks is push one down at a time and see if it will turn the tractor then push both brakes down and let the clutch out in low gear and see if the tractor stalls down some or pulls through them easily
  7. #7
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    yep.. good brakes will lock a wheel, and seriusly bog the engine with them locked and clutch out as WD said.
    have you adjusted yours? they use simple star adjusters.... plan old drum brakes..
  8. #8
    New Member
    Join Date
    Jul 2010
    Posts
    15
    Orland, CA.
    tym 433
    Wonderful old tractors. I had a '54 till a couple of years ago, my very first tractor. Two things come to mind. It doesn't have a "creeper" gear so something like tilling would be a problem and watch out for crud in the fuel tank. It's a gravity feed system and I had more problems with clogged fuel lines,jets,etc. than everything else combined. In fact, the reason I got rid of it and bought a new one was because it died(again) while I was mowing and I walked into the house FURIOUS and vowing to go get a new one. My son happened to be standing there and,well...
  9. #9
    Join Date
    Mar 2002
    Posts
    52,744
    Central florida
    yep.. gotta keep the 3 screens in place and clean in the fuel system...
  10. #10
    New Member
    Join Date
    Apr 2012
    Posts
    2
    Birmingham, Alabama
    1953 Ford Jubilee
    I have not adjusted them, mainly since they seemed to work ok, but the conditions admittedly were ideal. Obviously, I need to do that. I may just go ahead and rebuild them while I'm at it, just to be completely safe. I've rebuilt everything else to get this old tractor running; what's one other thing, right? Hydraulics are a little sketchy, too; they are probably next.
Similar Threads
  1. WANTED: Restored 1953 Ford Golden Jubilee Tractor
    By BigMikeFL in forum New Holland Buying/Pricing
    Last Post: 10-14-2013, 12:04 AM
  2. New Owner of a 1953 Ford Jubilee
    By twtrout in forum New Holland Owning/Operating
    Last Post: 07-18-2009, 01:39 AM
  3. 1953 Golden Jubilee
    By SABULA FARMER in forum New Holland Owning/Operating
    Last Post: 02-26-2007, 06:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
