parts list and diagram for rotor style oil pump used till 64.. also called a g-rotor:
AR D1NL6600A HYDRAULIC PUMP Pump Assy., Oil, L/Screen & Cover, This part is a direct replacement for C3NN6621B, When Replacing C3NN6621A, Also Use (1) D1NL6622A Cover & Inlet Tube and (1) B9NN6730A Plug, When replacing Gear Type Pump W/
1 B9NN6730A PLUG Plug, Oil Pan Drain, W/D1NL6600A, Years: 01/01/1961-12/31/1964
1 1 C1AE6604C Body, Oil Pump, Except Diesel, Years: 01/01/1961-12/31/1963
1 1 C3NN6604A Body, Oil Pump, Diesel, Years: 01/01/1963-12/31/1964
1 1 C4AE6604A Body, Oil Pump, Except Diesel, Years: 01/01/1963-12/31/1964
2 1 EAF66646D SHAFT Shaft, Oil Pump, Intermediate, Hex Drive, Years: 01/01/1961-12/31/1964
3 1 EAA6659A GASKET Gasket, Oil Pump to Block, Years: 01/01/1961-12/31/1964
4 2 EAF6638A BOLT Bolt, Oil Pump Mounting, Years: 01/01/1961-12/31/1964
5 2 PL PROCURE LOCALLY Washer, Lock, 3/8", Years: 01/01/1961-12/31/1964
6 2 PL PROCURE LOCALLY Nut, Hex, 3/8"-24, Years: 01/01/1961-12/31/1964
7 1 B9AE6674A PLUNGER Plunger, Oil Pump Relief Valve, Years: 01/01/1961-12/31/1964
8 1 86608463 SPRING Spring, Oil Pump Relief Valve, Years: 01/01/1961-12/31/1964
9 1 C2AE6A616B PLUG Plug, Oil Pump Relief Valve, Years: 01/01/1961-12/31/1964
10 1 B2AE6608A Rotor & Shaft Assy., Oil Pump Drive, 134", W/B3NN6621A, Years: 01/01/1953-12/31/1956
10 1 C0AE6608A ROTOR Rotor & Shaft Assy., Oil Pump Drive, .4935 Dia., W/C0NN6621A & C0NN-6621-B, Years: 01/01/1961-12/31/1963
10 1 C3AE6608B ROTOR Rotor & Shaft Assy., Oil Pump Drive, .5855 Dia., Years: 01/01/1961-12/31/1964
11 1 C0NN6616A SPARE PART Cover, Oil Pump, Except Diesel, Years: 01/01/1961-12/31/1964
11 1 C0NN6616B COVER Cover, Oil Pump, Diesel, Years: 01/01/1961-12/31/1964
2 PL PROCURE LOCALLY Bolt, HH, 1/4"-20 x 1", Except Diesel, Years: 01/01/1961-12/31/1964
2 PL PROCURE LOCALLY Washer, Lock, 1/4", Except Diesel, Years: 01/01/1961-12/31/1964
12 1 C0AE6626A GASKET Gasket, Body to Inlet Tube Flange, Except Diesel, Years: 01/01/1961-12/31/1964
12 1 C0NN6626A GASKET Gasket, Oil Pump Cover to Inlet Tube Flange, Diesel, Years: 01/01/1961-12/31/1964
13 1 C0NN6615A COVER Cover & Inlet Tube Assy., Screen, 134" Offset Only, Start Year: 01/01/1964
13 1 C0NN6615B COVER Cover & Inlet Tube Assy., Screen, Except Diesel, Years: 01/01/1961-12/31/1964
2 PL PROCURE LOCALLY Screw & Lockwasher, HH, 5/16"-18 x 1", Except Diesel, Years: 01/01/1961-12/31/1964
13 1 C0NN6622D Cover & Inlet Tube Assy., Screen, Diesel Offset Only, Years: 01/01/1961-12/31/1964
13 1 D1NL6622A COVER Cover & Inlet Tube Assy., Screen, Except Offset, Years: 01/01/1961-12/31/1964
2 PL PROCURE LOCALLY Bolt, HH, 1/4"-20 x 1.12, Diesel, Years: 01/01/1961-12/31/1964
2 PL PROCURE LOCALLY Washer, Lock, 1/4", Diesel, Years: 01/01/1961-12/31/1964
14 1 C0NN6A661A BRACKET Bracket, Oil Pump Inlet Tube, Diesel, Years: 01/01/1961-12/31/1964
15 1 C0NN6A628A GASKET Gasket, Cover to Oil Filter Inlet Tube, Years: 01/01/1961-12/31/1964
16 1 C0NN6716B TUBE Tube Assy., Oil Filter Inlet, Except Diesel, Years: 01/01/1961-12/31/1964
16 1 86579306 TUBE Tube Assy., Oil Filter Inlet, Diesel, Years: 01/01/1961-12/31/1964
17 2 PL PROCURE LOCALLY Bolt, HH, 1/4"-20 x 1.12, Years: 01/01/1961-12/31/1964
18 2 PL PROCURE LOCALLY Washer, Lock, 1/4", Years: 01/01/1961-12/31/1964
19 1 B9NN6A629A NUT Nut, Oil Filter Inlet Tube, 7/8-18 x 1/2", Hollow, Production installed Dyn. Balancer, Diesel, Years: 01/01/1961-12/31/1964
19 1 B9NN6A629B NUT Nut, Oil Filter Inlet Tube, 7/8-18 x 2.08", Hollow, Field installed Dyn. Balancer, 172" Diesel, Years: 01/01/1958-12/31/1959
19 1 B9NN6A629B NUT Nut, Oil Filter Inlet Tube, 7/8-18 x 2.08", Hollow, Field installed Dyn. Balancer, 144" Diesel, Years: 01/01/1958-12/31/1960
19 1 EAF66738B NUT Nut, Oil Filter Inlet Tube, Except Diesel, Years: 01/01/1961-12/31/1964
20 1 EAF66644A SEAL PROTECTION Seal, Oil Filter Inlet Tube, Years: 01/01/1961-12/31/1964
