texasnative1973
I recently rebuilt the hydraulic pump on my 2N. It was working just fine for a little while. After rebuilding the pump the original clutch friction disk flew apart. I put a new clutch kit and a resurfaced fly wheel in and was back in business. The next part to come unwound was the overrun connected to the brush hog. When this quit I lifted the 3 point to make sure I didn't shear anything. The bush hog started lifting and then it slammed to the ground and will not lift anymore. I am starting to pull my hair out. The linkages and control valve are in good shape, the lift piston and rings are in good shape, the fluid tube is not cracked, and the fluid is brand new specific for N tractors. The lift arms will lift with nothing attached and I can see the arms lift up a little when the lever is pulled up. Does anybody have any suggestions, I am running out of hair... Thanks
