barros57
ok, so here's the deal. I really hope someone on here can help me out here.
The tractor is later model 50-52 ford 8n (or so I think).
Anyways, the the charging system is not charging. I thought the generator might be bad, but I took it off and connected a battery to it and it spun just like an electric motor so It seems fine to me.
The tractor bogs down and dies when I touched the voltage regulator (It has rubber feet which isolate it from the frame which are worn). The voltage regulator number is VRR-4008-A. I tried polarizing it, but there are no markings on this voltage regulator to tell which terminals are which.
1) The battery negative was grounded but I thought these tractors were 6v pos ground? is this wrong?
2) I just bought a voltage regulator on ebay that I am hoping will work it is an A-circuit 6volt for a ford 8n. is this the same as my frame isolated VRR-4008-A voltage regulator?
3) 2 brush / 3 brush generator?
Here are some pics
Here are some pics
