Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Jun 2012
    Posts
    20
    Miramichi, NB
    1948 Ford 8N, 1974 Ford 3000
    Default Ford 3000 Price opinion and suggested checks
    Hi all. Love the forum!
    I'm looking to upgrade from the beat up 8N I own and have spotted a Ford 3000 at the local dealer here in New Brunswick. Could use some advice on things to check and what you all think of the pricing.
    The unit has been sitting on the lot since last summer. It's a '74 diesel 8 spd with live pto, diff lock and the remote hydraulics on the rear. It has 4800+ hours with half decent tires showing some weather cracking in the center of the tread. Rims are a little rusty, especially around one tire valve. I believe they are filled with calcium.
    When I stopped by early last week it would not turn over - idiot lights but no solenoid click, nothing. They had a mechanic out from the main shop and he replaced the voltage regulator and the battery, according to the salesman. When I arrived about 4 hours later it was cold (as cold as a mid June is here in Canada - about 68F that day, so not very). It turned over and started right up. On start up there was no smoke. It ran smooth and steady. It shutdown cleanly and started right up several times after driving around for a while.
    Things I checked:
    Looked everywhere for leaks, including the ground around where it sat. It's been in the same spot for a long time and no sign of any leaks. There are some "wet spots" on the chassis but no dripping.
    I ran the RPMs up to about 15-1600 and let the clutch out slowly in 8th with the brakes on and it stalled out. Same thing in 2nd bogged the engine down and it moved begrudgingly. So, seems clutch and brakes are in ok shape.
    All I could really do to check the PTO was engage and disengage it. There was no grinding with the clutch in when I engaged the PTO lever. It spun up when I let the clutch out and came to a fairly quick stop when I engaged the clutch again. Best guess is the clutch is not stuck, no idea of the shape of it.
    Same story with the 3pt...not much to check it with. When I arrived it was up so I assume it is not in bad enough shape to fall on its own - not really a test. I put my 280lb frame on it and it did not budge with the engine off. I did rise and fall smoothly and quietly with the position control.
    It drove smooth in several gears, forward and reverse, low and high range. No clunks, or whines, or shimmies. The only thing odd was the diff lock. I engaged it and sort of expected to be able to feel it trying to turn with it locked but there was no difference...not too sure on this one.
    In my opinion it's in fairly good shape for a 74. I'm just not sure about the price. On first visit they told me $4000. So when I went back and they had it running we haggled a bit with me at 3k and them holding strong at 4k. We ended up at 4k taxes in (13%, so actual price about $3550). I was thinking going into this I'd be willing to spend about $3500.
    What do you guys think? Am I lowballing this guy or is 4k about right?
    I'm taking a run in tomorrow to see if we can chisel a few dollars off. Anything else you guys can think of that I can look for in such a limited scenario?
    Pics below:
    Ford 3000 Price opinion and suggested checks-100_2458-jpgFord 3000 Price opinion and suggested checks-100_2500-jpgFord 3000 Price opinion and suggested checks-100_2504-jpgFord 3000 Price opinion and suggested checks-100_2514-jpgFord 3000 Price opinion and suggested checks-100_2515-jpg
  2. #2
    Veteran Member whodat526's Avatar
    Join Date
    Apr 2010
    Posts
    1,529
    deridder louisiana
    fords
    Default Re: Ford 3000 Price opinion and suggested checks
    Quote Originally Posted by Truro411 View Post
    Things I checked:
    Pics below:
    i just sold one with less paint on it and a 67 model but everything worked and all it needed was a good paint job there were no leaks or drips and i got 4500 dollars for it
  3. #3
    Advertiser sweettractors's Avatar
    Join Date
    Jul 2003
    Posts
    7,616
    Central Kentucky
    JD 6403 CHA-JD 3130 CHA
    Check for oil in the radiator or water or cream colored oil on the dipstick. Make sure the weep hole under the bell housing is open. Ken Sweet
    http://www.sweetfarms.com/
    Sweet Farm Equipment LLC (Internet Sales, Shipping All States)
    Shipping Facility
    1815 Defries Rd., Canmer, Ky 42722 Toll Free 1-866-528-3323
    Ken Sweet sweet@scrtc.com
    Shipping Example: Can ship 800 lbs from Ky. to Dallas for $165
    The Northeast shipping corridor is a little more expensive.
  4. #4
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    3500$ is generally a good price on a late deisel 8spd 3000.
    I'm surprised it begrudgingly moved in 2nd. it should ahve taken off brakes or no brakes. I'm kinda also surprised you could stall it in 8th.. it must have superb brand new brakes and you must have been at idle.
    check pto shaft for in / out slop. if it has it.. get it fixed fast.. it needs usually a bearing and seal and perhaps a split ring or bearing carrier.. not hard work...
  5. #5
    New Member
    Join Date
    Jun 2012
    Posts
    20
    Miramichi, NB
    Thanks all for the replies.
    In 8th I was running at about 1500 RPM, not full throttle. In 2nd I was only running about 7-800 RPM...was a quick and dirty test but from driving it around the brakes do seem really good.
  6. #6
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    an uncommon find on a ford..
  7. #7
    New Member
    Join Date
    Jun 2012
    Posts
    20
    Miramichi, NB
    Tell me about it. I've done the brakes on the 8N and I think one is leaking again. Could be an old oil stain, could be new.
    Oh well, luckily my land is not too hilly! =-)
    Well, I pulled the trigger this morning. $3800 taxes in with a beat to heck Bush Hog for another $400...to be delivered tomorrow AM. The bush hog should be enough to get some brush beat down in the front of my fields. I'll probably have to look to a new one sometime next year or the year after to really go after clearing my fields back to grass from dogwood heaven.
    Now to find a Ford bucket for cheap!
  8. #8
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    too bad soo much on the hog. beaters are usually 200$ here. oh well.. you jump on the ones ya can, and don't look back..
    post pics when ya get the goodies home!
  9. #9
    New Member
    Join Date
    Jun 2012
    Posts
    20
    Miramichi, NB
    Sorry took so long posting pics. Got her home and now the worrying begins. What will go wrong? :-)
    So far the good old steering column leak but I've already got the seal and O ring. PS fluid reservoir was pretty near empty and when I filled it up it looks like Choc milk now...more work! As well there seems to be a noise from either the CAV inj pump or the water pump...kind of a clicking/pinging that I can hear over the engine.
    Next on the list is a far more serious issue...won't start. But I'll start a new thread on that one...
    Ford 3000 Price opinion and suggested checks-img_20120622_113238-jpgFord 3000 Price opinion and suggested checks-img_20120622_113319-jpg
  10. #10
    Join Date
    Mar 2002
    Posts
    52,657
    Central florida
    CAV pump really? kind of expected a simms on it. if a simms.. you'd need to check the cam box for oil.
    won't start.
    dead battery or?
Similar Threads
  1. Price Check ford 3000 price
    By jonboy1981 in forum Buying/Pricing/Comparisons
    Last Post: 10-08-2012, 09:52 AM
  2. Price Check L-series price checks
    By LSUalum in forum Kubota Buying/Pricing
    Last Post: 01-20-2007, 11:08 AM
  3. Price Check JD 790 Price Checks
    By jordanh in forum John Deere Buying/Pricing
    Last Post: 09-28-2006, 09:46 PM
  4. Price Check 1965 Ford 3000 Super Dextra price
    By F350 in forum Buying/Pricing/Comparisons
    Last Post: 11-04-2003, 11:14 AM
  5. Price Check Price checks on JD455
    By BXmark in forum John Deere Buying/Pricing
    Last Post: 09-13-2001, 12:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
