Page 10 of 13 FirstFirst ... 78910111213 LastLast
Results 91 to 100 of 123
  1. #91
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    175
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    It's still a nice tractor SG, you put some new shoes on it looks good
  2. #92
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,539
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: A new NAA project now someday a new loader
    both of 'em got new shoes. 13.6's for the 740 and 14.9's for the 950 . the 14.9's were mismatched.. but couldn't pass up good rubber.
  3. #93
    Join Date
    Aug 2009
    Posts
    721
    Dallas Oregon
    Mitsubishi MT372, Ford NAA
    Default
    As promised some pictures....don't worry i only raised the loader to full height for the photo op.
    Not to pretty but getting to be more reliable.
    A new NAA project now someday a new loader-forumrunner_20130507_192904-png
    A new NAA project now someday a new loader-forumrunner_20130507_192833-png
    A new NAA project now someday a new loader-forumrunner_20130507_192845-png
    A new NAA project now someday a new loader-forumrunner_20130507_192920-png
  4. #94
    Join Date
    Aug 2009
    Posts
    721
    Dallas Oregon
    Default
    So finally got some work done today. Not without issues but the old girl is working better each go. Here are the things i need to address soon.
    I found that the right ps cylinder is leaking. Unfortunately it is leaking at the at the seal rather than the hose. Got a feeling it will be an expensive one to have fixed.
    3 times while running the motor shut down. The govenor started searching then the motor stopped. Waiting about 20 minutes was the "fix". Not sure if it is vapor locking or something...but it is kind of odd.
    Oil pressure is good. 40 when cold between 30 and 40 once warm.
    Not sure if draft control is working right. It only has 2 positions. When the lever is up ( pointing skyward) the 3point goes up when the main lever is raised. When the draft control points forward all 3 point action stops and everything sinks
    Now that the loader is actually full of fluid and working i find it is actually power up and down. It will lift the front off the ground quite easily. My question is what kind of stresses or loads should i be concerned with if thes happens (i don't see a lot of reason to do it)?
    Still trying to decide on the value of the giant teeth on the bucket. Might cut them off.
  5. #95
    Gold Member DaveOmak's Avatar
    Join Date
    Sep 2009
    Posts
    436
    Omak, Washington
    '53 Jubilee
    Sounds like the draft control is working properly... I use my sub-soiler on draft control.... When the sub-soiler digs in, using the 3-point position lever, you can adjust the amount of pressure it takes to lift the 3-point up.... also, the 3 position top link bracket allows for leverage on the draft control mechanism to lift easier or when it's under more pressure..... That doesn't make much sense but I'm having trouble describing the function of the hydraulics in the draft control system..... someone help me out here..... Dave
    I found this link......
    http://www.tractorbynet.com/forums/o...n-how-why.html
    Nice install on the aux hyd pump.... Is the flex hose the supply hyd fluid from a resevoir ..
  6. #96
    Join Date
    Mar 2002
    Posts
    52,539
    Central florida
    imho.. keep the teeth!
    as for draft. it will likely only lift the 3pt at the very rear of the stroke.. last 2 "
    hunting gov and then death usually means it fuel starved. check tank tap and flow to and thru carb bown.. and make sure no vacume on tank.
    vapor lock is not what i'd expece on a gravity feed system with no fuel pump.
  7. #97
    Join Date
    Aug 2009
    Posts
    721
    Dallas Oregon
    Default
    That hose is the supply from the tank to the pump. The tank is the frame. Can't claim much design credit just a bit of clean up. Thanks for the link.
  8. #98
    Join Date
    Aug 2009
    Posts
    721
    Dallas Oregon
    Default
    I wouldn't expect vapor lock as well. I removed the "auxillary" fuel filter that it had... Which helped. The sediment bowl might be showing a bit of water...hopufully sitting overnight will settle it further and i will drain it.
  9. #99
    Join Date
    Aug 2009
    Posts
    721
    Dallas Oregon
    Default
    Blew out the fuel line....flow went from a trickle to a full hose pour. Ran great for 45 minutes then fuel starved again....guess i need a tank flush...and cross fingers that it isn't some kind of tank coating coming off.
  10. #100
    Join Date
    Mar 2002
    Posts
    52,539
    Central florida
    pull the tap and take a look at the screen on top..
Similar Threads
  1. Replies: 6
    Last Post: 08-31-2011, 01:05 PM
  2. NAA w/ Freeman Loader Color
    By MH49 in forum General Vintage Tractors
    Last Post: 10-22-2010, 10:26 PM
  3. Trailer hauling gone someday?
    By Farmwithjunk in forum Trailers & Transportation
    Last Post: 07-14-2006, 01:30 AM
  4. Trailer hauling gone someday?
    By Farmwithjunk in forum Owning/Operating
    Last Post: 07-10-2006, 09:57 PM
  5. I'm going to miss all this fun someday
    By itsmecindi in forum Related Topics
    Last Post: 07-12-2003, 11:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
