Page 8 of 13 FirstFirst ... 567891011 ... LastLast
Results 71 to 80 of 123
  1. #71
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: A new NAA project now someday a new loader
    sounds good so far!
  2. #72
    Join Date
    Aug 2009
    Posts
    724
    Dallas Oregon
    Mitsubishi MT372, Ford NAA
    Default
    Located and cleaned the loader filter. Also found this seal floating around in there. It is smaller than the filter so i'm not sure where it came from.
    I also built a simple grill with expanded steel to protect that expensive radiator.
    A new NAA project now someday a new loader-forumrunner_20130417_204955-png
    A new NAA project now someday a new loader-forumrunner_20130417_205023-png
    A new NAA project now someday a new loader-forumrunner_20130417_205111-png
    A new NAA project now someday a new loader-forumrunner_20130417_205156-png
  3. #73
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    deffintely looks better clean!
  4. #74
    Join Date
    Apr 2011
    Posts
    1,174
    Erie Pa.
    Montana R4944, Ford Jubilee, Ford 621, Ford 841
    Just read your thread you must be having fun. But I have a question, where did the power steering come from? As far as I was aware power steering didn't come out til the o1 series, of course it would fit right on the NAA no problem and from the looks of the hydraulic plate it sure is an NAA. Just curious is all.
    Montana R4944
    Ford Jubliee, Ford 841, Ford 621 industrial with FEL & BH
  5. #75
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    power stering was available as an option from 55+
    my 1955 issued manual shows this option..
    a ps setup from any 55-64 ag chassie can be put on a NAA etc.
  6. #76
    Join Date
    Aug 2009
    Posts
    724
    Dallas Oregon
    Default
    Well i bought the tractor with the ps. I suspect soundguy is right in that it came from a post 55.
    The pump on this one is on the right side of the engine (opposite the generator) and is driven by it's own belt off a two groove crank pulley.
    It was empty of fluid when i got it but seems to work once fluid was added.
    The local tractor scrap yard told me the ps assembly was worth 1200 bucks so i figured it had extra value if the motor didn't work out....but so far so good.
    My hydro hoses shipped today
  7. #77
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    keep an eye on the fluid. if it's a super small leak... like needs add 1/year.. I wouldn't worry too much about it.
  8. #78
    Join Date
    Aug 2009
    Posts
    724
    Dallas Oregon
    Default
    Yeah i'm not going to be chasing every small leak...as someone else on this forum said the leaks are just the tractor marking its territory.
  9. #79
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    if it was a parade machine 100% resto.. I'd reseal or repalce the pump.. as a worker.. a very MINOR oil leak wouldn't overly bother me.
  10. #80
    Join Date
    Aug 2009
    Posts
    724
    Dallas Oregon
    Default
    Well my hoses arrived on wed while i was away on a trip. (Joshua tree nat'l park). Got back to the machine this evening. One box is marked as an 84 inch long hose but contains a 60 inch hose...!*&@#$/*....anyone have a hose stretcher i can borrow?. Technical support doesn't open till monday. Given the money saved it was probably worth it but had i had them made locally i'd be rolling by now.
Similar Threads
  1. Replies: 6
    Last Post: 08-31-2011, 12:05 PM
  2. NAA w/ Freeman Loader Color
    By MH49 in forum General Vintage Tractors
    Last Post: 10-22-2010, 09:26 PM
  3. Trailer hauling gone someday?
    By Farmwithjunk in forum Trailers & Transportation
    Last Post: 07-14-2006, 12:30 AM
  4. Trailer hauling gone someday?
    By Farmwithjunk in forum Owning/Operating
    Last Post: 07-10-2006, 08:57 PM
  5. I'm going to miss all this fun someday
    By itsmecindi in forum Related Topics
    Last Post: 07-12-2003, 10:36 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
