Results 1 to 10 of 121
07-11-2012, 04:31 PM #1Gold Member
- Join Date
- Aug 2009
- Posts
- 336
- Location
- Dallas Oregon
- Tractor
- Mitsubishi MT372, Ford NAA
A new NAA project now someday a new loader
So I have been bugging my wife for a tractor with a loader. My little Mitsubishi is great but is not so equipped. Here is the latest project...Just got it home less than an hour ago. The motor is free although the clutch is not, but hope springs eternal. It appears to have a low range selector (see pic) and a Shawnee loader. Next to make it run. Soundguy has posted detailed descriptions on how to bring theses old girls back to life, and I will go through that procedure.
07-12-2012, 10:16 AM #2Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,134
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: A new NAA project now someday a new loader
so far I see pwer steering.. a huge plus. but more cimportantly. i think I see a large lever by the pto lever.. that may be nice. I can't see the detail on my lil screen though. might be a rear pinion clutch live pto kit.
generally the naa live pto was a hyd kit and would need a line off a special pump on the nose of the hydro pump over to the kit. there was a kit for the 8n that was straight mechanical.. I bet an enterprising person could adapt one. in any case.. sans the line.. it is possibly one of the other rear aux trans. I simply can't see it in enough detail with my mobile device..
howard shifters are on the right under the 3pt lever.. and evereets are a spacer. so it MIGHT be the rre one. clean the palte up and post info.
I don't see a hyd line though... got a close up of the engine pump?
go ahead and block clutch while working on her..
07-12-2012, 12:28 PM #3Gold Member
- Join Date
- Aug 2009
- Posts
- 336
- Location
- Dallas Oregon
- Tractor
Yep it does have power steering. Leaking a bit, but functional. There is a large lever by the PTO lever. The seller called it the sherman low range but I'm not sure he has that right.
I'll post a few more pictures of the engine pump and levers. The clutch is blocked. I hope to get working on this next week...
07-12-2012, 02:29 PM #4Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,134
- Location
- Central florida
- Tractor
sherman 'underdrives' were installed ahead of the tranny. lever ont he left side. underdrives were rare.. overdrives pretty common.. and combo's the most common. a reverser was available as well.
plenty of people made aux trannies.
clean up that plate and look for info on it.. and post detailed pics.
07-27-2012, 06:19 PM #5Gold Member
- Join Date
- Aug 2009
- Posts
- 336
- Location
- Dallas Oregon
- Tractor
So here is a small update. I finally managed to get some time to work on the NAA.
The serial number stamped below the flat in front of the starter is 93375. It also has the text "NAA 4024 C" cast into the transmission case just below the PTO engage lever.
The plate that the PTO engagement lever comes out of along with a mystery lever has the text "pat. applied for 10128-53" (see photo). There are no hydraulic lines feeding into this area. The engine block has the text "DN1L 80150" cast into the right side at the base of the block.
The left running board appears to formally have a tool box in it. It has been welded up with diamond plate...see the pattern difference.
I removed the hood to start to give it a thorough cleaning and found a broken wire at the starter solenoid Got that fixed and now the solenoid makes a buzzing noise but the starter doesn't crank.
07-27-2012, 10:21 PM #6Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,134
- Location
- Central florida
- Tractor
need a more complete pic of the pto shifter plate.
as for the solenoid.. is it a ford solenoid? how is it wired?
07-29-2012, 01:56 PM #7Gold Member
- Join Date
- Aug 2009
- Posts
- 336
- Location
- Dallas Oregon
- Tractor
07-29-2012, 08:26 PM #8Gold Member
- Join Date
- Aug 2009
- Posts
- 336
- Location
- Dallas Oregon
- Tractor
So I bypassed the solenoid to get the engine to crank. The battery is strong, pulled all the plugs and did a compression test. The results in PSI...
CYL Dry Wet
1 110 145
2 40 45
3 50 45....I repeated this several times...not sure why it went down
4 115 130
These results reflect roughly what the previous owner told me. What do these number mean to you?
Thanks
07-29-2012, 11:21 PM #9Silver Member
- Join Date
- Jun 2012
- Posts
- 145
- Location
- Deville,La
- Tractor
- JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
Sounds like you may have a blown head gasket between number 2 and three cylinders
07-30-2012, 01:40 AM #10Super Star Member
- Join Date
- Jul 2011
- Posts
- 10,526
- Location
- Yanceyville, North Carolina
- Tractor
- Kubota L4400
Best wishes.
The PUPIL who does not surpass his Master, fails his Master.
Similar Threads
I may get around to mounting an extinguisher someday.
By The Haymaker in forum SafetyReplies: 6Last Post: 08-31-2011, 12:05 PM -
NAA w/ Freeman Loader Color
By MH49 in forum General Vintage TractorsReplies: 6Last Post: 10-22-2010, 09:26 PM -
Trailer hauling gone someday?
By Farmwithjunk in forum Trailers & TransportationReplies: 35Last Post: 07-14-2006, 12:30 AM -
By Farmwithjunk in forum Owning/OperatingReplies: 19Last Post: 07-10-2006, 08:57 PM -
I'm going to miss all this fun someday
By itsmecindi in forum Related TopicsReplies: 2Last Post: 07-12-2003, 10:36 AM
