Results 1 to 10 of 10
  1. #1
    New Member korey5770's Avatar
    Join Date
    Nov 2011
    Posts
    9
    Ford 2000
    Default 703 or 720 loader on ford 2000?
    Hello I have been in the market for a Ford Loader to mount on my 68' 2000. I found one but not sure if it will fit. The model number on the tag says I9-97 and the serial number is 7355 I think it might be a 703 or 720 Loader. The tractor this is mounted on is a 50"s ford 861 power master, I believe. The question I have is, will this mount on my 2000??
    Attached Thumbnails Attached Thumbnails 703 or 720 loader on ford 2000?-image-2479409001-jpg
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 703 or 720 loader on ford 2000?
    a dearborn 19-97 is an industrial loader with da lift cyls.. a 105 model was available with sa cyls... it was designed to fit the naa and 6XX/8XX tractors.. kits were available for 8n, ferguson 20/30/35 and oliver 55. IE.. this loader was out BEFORE the 65+ models came out.
    will it fit a 65+? with a torch and welder.. I'd guess yes. not with the brackets it's using for a 00 though....
    a 730 loader is what would fit your 65+ 3 cyl.
    soundguy
  3. #3
    Join Date
    Nov 2011
    Posts
    9
    Ford 2000
    Default
    Thanks for the quick response sound guy!
    Is dearborn made by ford? Here is a picture of the tag and a couple other photos. I took some rough measurements and everything seems close but it's hard to tell without having the loader right there.
    Attached Thumbnails Attached Thumbnails 703 or 720 loader on ford 2000?-image-1235076062-jpg   703 or 720 loader on ford 2000?-image-4034594780-jpg   703 or 720 loader on ford 2000?-image-3926426352-jpg
  4. #4
    Join Date
    Nov 2011
    Posts
    9
    Ford 2000
  5. #5
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    you found it.. but yes.. d/f same deal of that one..
  6. #6
    Join Date
    Nov 2011
    Posts
    9
    Ford 2000
    Default
    Is a 730 the only Loader that will fit my 2000? They are hard to come by and pricey when you do find them. Also it seem a little heavy for the tractor.
  7. #7
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    the 730 is a specific model made for the 3 cyl.. it's not too heavy for it.
    there are MANY laoders that will fit the small 3 cyl fords..
  8. #8
    New Member
    Join Date
    May 2014
    Posts
    1
    prattsburgh NY
    Ford 3000
    I have a Ford 3000 tractor. I found a Ford front end loader Model 703 Year 19-97 Serial# 13867 Will this loader fit my tractor? Or do I need to look for a Model 730
  9. #9
    Join Date
    Nov 2011
    Posts
    9
    Ford 2000
    Default
    Like a wise man once said "With a torch and a welder..Yes". 730 would be nice but they don't give them away. I ended up finding a loader that was custom mounted on a 3000, bought it and slapped her on my 2000....works great, but I don't have a clue what it is.
  10. #10
    New Member
    Join Date
    May 2014
    Posts
    1
    CHARLO
    ford800
    So may i ask you who owns this loader ??I am looking for same loader for the cylinders..Thanks for any info
Similar Threads
  1. LA 703 Loader
    By jsborn in forum Kubota Owning/Operating
    Last Post: 06-09-2012, 12:02 AM
  2. Planters 703 ford corn planter
    By johnhoffman in forum Attachments
    Last Post: 05-14-2012, 11:27 AM
  3. Ford 703 Loader Filter
    By w00dman62 in forum Parts/Repairs
    Last Post: 09-20-2011, 10:14 AM
  4. BCS 720 YEAR 2000 MODEL CLUTCH HELP
    By antoniod in forum 2-Wheeled Tractors
    Last Post: 09-20-2010, 10:33 AM
  5. 703 loader weight capacity
    By simonmeridew in forum Kubota Owning/Operating
    Last Post: 06-08-2007, 11:08 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
