Results 1 to 8 of 8
  1. #1
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    139
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default '69 ford 4000
    I just got finished rebuilding the 201cid engine for my 4000, bled the fuel system and cranked till I got the air out and tightened the lines up. I'm not getting any fuel smoke while I crank on it, replaced the injectors with new ones. Do I have a problem with the injection pump? If I give it a small shot of starting fluid it starts rite up, I don't like using that crap to start an engine.
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    6,261
    Eastern NY
    Case 885, JD 730D, Oliver 660 Ford 4000
    Default Re: '69 ford 4000
    Quote Originally Posted by Varmint1 View Post
    Did you bleed the pump itself? Did you bleed the injector lines at the injector end?
    If no to either question, repeat the bleeding procedure correctly in the listed order.
    If yes to both questions, repeat anyway.
    Make sure the battery is fully charged so the required cranking speed can be achieved.
    If you can read this, thank a teacher.
    If you are reading this in English, thank a veteran.
  3. #3
    Join Date
    Jun 2012
    Posts
    139
    Deville,La
    Default
    I've bled the system at the pump and injectors numinous times and the same thing, I even pulled the little screen on the inlet of the pump and cleaned it. I forgot to mention that the tractor had sat up for years that the reason I had to rebuild the engine, # 1 cylinder was stuck, thanks for the info
  4. #4
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,106
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    pull start it.. then run it around a bit.. ( alot )..
    then shut her down and see where you are at.
  5. #5
    Join Date
    Jun 2012
    Posts
    139
    Deville,La
    Default
    Yesterday I finally got my injection pump back, didn't have time to work on it then stayed in the hay field till after dark. Today I installed the pump primed the system and cranked the engine, started in no time, let it run for a moment shut off and started again with no problem
  6. #6
    Join Date
    Mar 2002
    Posts
    42,106
    Central florida
    cool deal
  7. #7
    Join Date
    Jun 2012
    Posts
    139
    Deville,La
    Default
    Does UTF go in the transmission and hydraulic system on the '69 ford 4000
  8. #8
    Join Date
    Mar 2002
    Posts
    42,106
    Central florida
    yep.. power steering too...
Similar Threads
  1. 72 ford 4000
    By Con4000 in forum Parts/Repairs
    Last Post: 08-15-2012, 11:46 AM
  2. Is it a Ford 4000 or a Ford 871
    By Friar in forum Parts/Repairs
    Last Post: 04-25-2012, 09:14 AM
  3. Ford One Arm Loader 19-209 (711) & Ford 4000
    By rwacho in forum Ford Vintage Tractors
    Last Post: 12-25-2009, 11:18 PM
  4. Ford 4000
    By NDRick in forum Ford Vintage Tractors
    Last Post: 12-13-2007, 09:56 AM
  5. ford 4000
    By revg62 in forum Ford Vintage Tractors
    Last Post: 11-10-2005, 07:24 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
