Results 1 to 10 of 17
09-14-2012, 07:03 PM #1Silver Member
- Join Date
- Jun 2012
- Posts
- 144
- Location
- Deville,La
- Tractor
- JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
800 series sos trans
Where is all the filers in the SOS trans on an 800 series, also is there and stamped or casting on the engine to tell what size it is, one more thing the tph won't raise is there a filter that I need to clean?
09-14-2012, 08:51 PM #2Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,111
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 800 series sos trans
no filter on the 3pt.. if hyds have oil and you burped the pump.. unload valve is likley stuck.
sos filters are internal.. get a manual. ( ps.. it will be an 801, not an 800.. in fact.. more specifically.. 871 or 881 depending on pto usually.. ) 8XX is 172ci
09-14-2012, 09:05 PM #3Silver Member
- Join Date
- Jun 2012
- Posts
- 144
- Location
- Deville,La
- Tractor
SG this tractor I think was pieced together, the engine is painted olive drab and blue, the SOS has nine layers of paint on it, the diff is yellow and blue, the hood has USAF and then a number that I can't read fully, I have no idea of what engine I have, the casting number CONN6015 and I think G at the end. Is there a a way to put the pto in it, I know it's the 871 SOS trans so can I put a pto out put shaft in it I thinking the diff is an industrial
09-14-2012, 09:06 PM #4Silver Member
- Join Date
- Jun 2012
- Posts
- 144
- Location
- Deville,La
- Tractor
SG you said to burp the pump you talking about removing the plug at the top of the pump
09-14-2012, 09:45 PM #5Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,111
- Location
- Central florida
- Tractor
yes to burping the pump.
as to adding a pto to a sos that has none.. I'm not the guy to ask. go for rickb maybee. I'm really not an sos guy.
C0NN-6015G - 134 sleeveless late 1962-1964
C0NN-6015H - 144D late 1960-1964
C0NN-6015C - 172D-G late 1960-1964
C0NN-6015J - 172 late 1960-1964
if it's a G.. sounds like a 134.
should also likely have a spin on oil filter native i'm thinking.. no adapter...
09-15-2012, 09:17 PM #6Silver Member
- Join Date
- Jun 2012
- Posts
- 144
- Location
- Deville,La
- Tractor
Check out the 800 today, the engine is a 134, the hydraulics had water in the oil, drained and replaced the oil,bleed the pump and the lift picked all the way up and wouldnt come down, pulled the top cove to find the control valve stuck freed it up and install and check functions, it works now
09-15-2012, 09:26 PM #7Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,111
- Location
- Central florida
- Tractor
it's not uncommon for the uload valves to stick
09-15-2012, 09:33 PM #8Silver Member
- Join Date
- Jun 2012
- Posts
- 144
- Location
- Deville,La
- Tractor
This tractor reminds me of the old Johnny Cash song ( One Piece at a Time ), parts from several different tractors
09-15-2012, 09:42 PM #9Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,111
- Location
- Central florida
- Tractor
i have a 950 ford that was almost a running basket case.. I have parts from 8 other tractors on it.. some of them major components.. .. not just little bolt on parts!
i call it a reverse parts tractor!
09-15-2012, 09:50 PM #10Silver Member
- Join Date
- Jun 2012
- Posts
- 144
- Location
- Deville,La
- Tractor
One good thing about the Ford tractors most of the parts from different model will fit each other
Similar Threads
Tractor Sizing NAA, 600 or 800 series
By dhort in forum Buying/Pricing/ComparisonsReplies: 11Last Post: 07-17-2012, 09:05 AM -
Georiga Gravely 800 series for parts (GA)
By rlordr in forum Private Party AdsReplies: 0Last Post: 04-07-2012, 10:07 AM -
MF 35 with Kelley 800 series loader
By Coolvtfly in forum Massey Ferguson Owning/OperatingReplies: 0Last Post: 08-29-2011, 04:51 PM -
confused which series 6 or 800
By 20 20 in forum Ford Vintage TractorsReplies: 11Last Post: 03-29-2011, 09:12 PM -
800 Series Ford Questions
By morningwood in forum General Vintage TractorsReplies: 8Last Post: 04-10-2007, 09:08 AM
