Results 1 to 9 of 9
09-28-2012, 06:21 PM #1Member
- Join Date
- Sep 2012
- Posts
- 27
- Location
- edwards mo
- Tractor
- ford 861 ferguson to20
861 ford diesel oil presure
hi to everyone i am new here and just brought home a 861 the old oil persure gauge looked like it wasnt working like it shoud so i put a new one on and it works it holds 40 # with the rpms up its when you go back to an idle it drops to 20 or less i have a oil filter comeing for it and intend to change it before i use it much any advice on this from you guys that know what your doing ?
09-28-2012, 06:53 PM #2Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,146
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 861 ford diesel oil presure
20 hot idle and 40 hot throttle are 'safe' numbers.. but indicate a pretty well worn red tiger... well worn with LOTS of life left in it mind you.
I have some absolutely abused and used red tigers that run that sort of pressure.. and I expect them to keep doing that another decade or two before they get to be worrysome.
ideally, a good red tiger should start up cold and hit near 60 psi on cold oil with some throttle as the relief cracks in mid 50's... with hot idle pressures usually being over 40.
I used 15w40 C rated oil in 99% of my machines.
you may be lucky have have really thinned out oil. see what the oil change does for you.
standard cannister is a fram ch6pl or napa 1004 standard spin on is a fram ph8a, supertech st8a, motorfraft fl1a napa 1452 or 1515 etc... usually a 3$ spin on and 6$ cartridge..
post back if ya have any more questions.. 53-64 are my favorite ford years..
09-28-2012, 06:59 PM #3
Great tractor. Cant really add to what soundguy said. They are a high HP machine in a small package
Got any pics? Did you buy to use? Restore?
And welcome to TBN".........there is only one way to find out."
"Ok, hold my beer and watch this.........."
Ford 5500 Backhoe
Kubota L3400GST W/LA463 FEL
2005 Dodge 3500 4x4 Diesel
8N Rebuilt and restored
Bushhog 105 and 306 cutters
JD 261 3PH mower
3 Homemade wood hauling trailers
Dolmar 7900
Dolmar 6400 84cc ported BB kit and Muffler Modded
Sachs-Dolmar 120SI Ported
(4) Sachs-Dolmar 116SI Ported
Dolmar PS540
Sachs-Dolmar 115i
Sachs-Dolmar 117
Sachs-Dolmar 112
Dolmar 350 "dads"
09-28-2012, 08:52 PM #4Member
- Join Date
- Sep 2012
- Posts
- 27
- Location
- edwards mo
- Tractor
i got it to use but when i have the time i expect i will do some repainting and the like to it the tin work is not to bad a good degreaseing would make things look a lot better i got this tractor because it has a fel on it i will get a picture of it here when i can thank to you and soundguy have a good night mike
09-28-2012, 09:00 PM #5Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,146
- Location
- Central florida
- Tractor
get a service manual for it.. and don't forget to greae her and service the air filter... etc..
hyds, diffy, trans.. etc... radiator fluid..e tc..e tc..
09-28-2012, 09:44 PM #6Member
- Join Date
- Sep 2012
- Posts
- 27
- Location
- edwards mo
- Tractor
your right i need a good manul i bought a it manul when i got the oil gauge but it leaves a lot of stuff out any ideas on a good one would help thank you all mike
09-28-2012, 09:52 PM #7Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,146
- Location
- Central florida
- Tractor
the it manual is 'ok' it covers basic stuff. If you ever rebuild the engine or tranny.. I'd get the ford service manual .. untill then.. the I&T will get you changing oil.. repacking wheel bearings.. brakes and steering anf hyds / general chassis work outside of the trans and engine....
09-28-2012, 11:06 PM #8Silver Member
- Join Date
- Jun 2012
- Posts
- 145
- Location
- Deville,La
- Tractor
- JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
SG why do they call them red tigers?
09-29-2012, 02:55 PM #9Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,146
- Location
- Central florida
- Tractor
the ohv engine ie.. the 134 and 144 and 172 and 192 were the red tiger engine. was a big step up from the generally poor breathing design of L head flatty on the 9-2-8N
Similar Threads
New here w/ Ford 861
By jeff pk in forum Ford Vintage TractorsReplies: 117Last Post: 06-11-2012, 03:46 PM -
861 ford diesel tractor
By clrrf in forum New Holland Ag TractorsReplies: 0Last Post: 07-04-2011, 11:59 AM -
Oil presure on CK 30
By JDL538 in forum Kioti Owning/OperatingReplies: 6Last Post: 04-11-2011, 07:07 AM -
Iseki TL 2500 oil presure???
By pasajeroBg in forum IsekiReplies: 8Last Post: 04-08-2011, 03:53 PM -
low oil presure ym 2000
By garyd in forum YanmarReplies: 8Last Post: 11-15-2005, 06:18 PM
