Results 11 to 14 of 14
11-16-2012, 05:21 PM #11Member
- Join Date
- Nov 2012
- Posts
- 25
- Location
- Oxford, GA
- Tractor
- Ford/861D
Re: 861 oil persure
Mike,
My 861 is a diesel and I completly re-wired it from stratch. if you're still having issues understanding the wiring harness I believe I can help. Let me know.
Thanks. Tom
11-17-2012, 06:35 PM #12Member
- Join Date
- Sep 2012
- Posts
- 27
- Location
- edwards mo
- Tractor
- ford 861 ferguson to20
Re: 861 oil persure
i havent had a chanch to look at it very much i guess the factory starter button went out and some one put a button were the key switch goes my main question is on the righthand side is a switch the guy i got it from told me you turned it when you sta rted the tractor i thought it was for the manafold heater wich aint hooked up any wayi left it on by mistake and it ran the battery down and it looks to me to be hooked up on the ground side of the battery thanks for your help mike
11-19-2012, 08:44 AM #13Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,106
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Re: 861 oil persure
would need lotsmore info to go on that where one side of a mystery switch goes.
where's the other side go?
11-19-2012, 09:43 AM #14Platinum Member
- Join Date
- Dec 2007
- Posts
- 860
Re: 861 oil persure
Hi Mike - if you don't already have a battery disconnect switch on there, it might be a good idea.
I like this style:
Top Post Battery Master Cut-Off Switch | Princess Auto
(Canadian prices are usually 2x USA ones, even with our dollar at par or better.)
For an old diesel, you won't need the bypass fuse - gives you a fuse holder to use somewhere else.
The green knob has a threaded stud on the bottom, that makes the electrical contact when tight. Give it a turn or 2 loose, and the battery is totally disconnected. Unscrew the knob and remove it, and somebody would have to remove this fitting and reconnect the battery before they could start the tractor.
On many older tractors, add-ons often get wired directly to the battery, as opposed to the ignition switch.
Until you get all the wiring sorted out, this would help you avoid draining the battery, or letting the smoke out of the wires !
Always important to remember - electrics run on smoke - once you let the smoke out of the wires, things don't work anymore !
Rgds, D.Last edited by 3930dave; 11-19-2012 at 09:46 AM. Reason: clarity
Similar Threads
861 ford diesel oil presure
By mj58 in forum Ford Vintage TractorsReplies: 8Last Post: 09-29-2012, 02:55 PM -
New here w/ Ford 861
By jeff pk in forum Ford Vintage TractorsReplies: 117Last Post: 06-11-2012, 03:46 PM -
Best manual for an 861?
By jeff pk in forum Ford Vintage TractorsReplies: 4Last Post: 05-01-2012, 08:25 PM -
861 Ford
By Art V in forum Parts/RepairsReplies: 5Last Post: 07-04-2007, 03:54 PM -
861 Ford
By Art V in forum Parts/RepairsReplies: 1Last Post: 07-04-2007, 03:51 PM
