Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 49
  1. #11
    Bronze Member kool cat's Avatar
    Join Date
    Oct 2012
    Posts
    56
    Marlbank,ont
    Kubota 23s
    Default Re: 8n wont start
    ok i'll have to look at that tomorrow,
    Thanks
  2. #12
    Join Date
    Oct 2012
    Posts
    56
    Marlbank,ont
    Kubota 23s
    just to let all know i got the tractor running. the wire from the distributor to the coil was too heavy.
  3. #13
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,772
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    to heavy? that makes no sense? it may have had a bad connection and when you changed it to a lighter wire it cleane dthe connection and worked.
    you could have a peiec of 1/0 wire connecting them up.. or a solid ingot of copepr conencting them and it would work fine.
    too heavy wasn't the issue.
    too bad of a conenction was...
    ps.. if that other ford was a 46.. it was a 2n.. or at least the egine was from a 2n...
  4. #14
    Join Date
    Oct 2012
    Posts
    56
    Marlbank,ont
    Kubota 23s
    with the thicker wire i got 0.04 volts at the distributor, with the thinner wire I got 6.12 volts. I dont know what to say?
  5. #15
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,344
    Central Ohio
    Kubota MX5100
    Quote Originally Posted by kool cat View Post
    Bad connection
    Soundguy is right. Wire size dont matter on that.
    Anyway...glad you got it running. The 8n's are pretty easy and a good tractor to learn to work on
    How about posting some pics when you get a chance?
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #16
    Join Date
    Oct 2012
    Posts
    56
    Marlbank,ont
    Kubota 23s
    ya your right doesnt matter about the wire, its runnng after two years sitting in a field. i'll see if i can get the pics to upload 8n wont start-t2ec16nhjhie9nysegi-bq-jhzh-48_35-jpg8n wont start-kgrhqj-l-fbkg-mdtvbq-jh
  7. #17
    Join Date
    Apr 2008
    Posts
    18,344
    Central Ohio
    Kubota MX5100
    Looks like a nice project.
    Keep an eye on that front axle with that loader. The 8n didnt have a super strong front end, and has lots of things that can wear out.
    Do you know if it has the sherman transmission? (It would have a dog-leg shaped lever on the transmission case just forward of the clutch pedal.)
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #18
    Join Date
    Mar 2002
    Posts
    52,772
    Central florida
    simple physics.
    heaver conductive wire is LESS of a voltage drop than thinner wire of same conductor type.
    unless you have magic powers to change those laws.. the reasonable answer was you had a bad conenction and the very ACT of changing out the wire, corrected the bad connection.
    remember. sometimes a cigar is just a cigar....
    not every part ever changed in history was a bad part. that's why diagnostic techniques usually yeild cheaper repair bils in the long run due to not repalcing good parts..
    glad you got er up.
  9. #19
    Join Date
    Oct 2012
    Posts
    56
    Marlbank,ont
    Kubota 23s
    like this 8n wont start-imag0352-jpg
  10. #20
    Join Date
    Mar 2002
    Posts
    52,772
    Central florida
    wrong spot.. that's simple the clutch linkage
    look up...
Similar Threads
  1. another 8n that wont start.
    By Adj100 in forum Ford Vintage Tractors
    Last Post: 08-30-2012, 11:54 AM
  2. 9N wont start
    By wadeschields in forum Ford Vintage Tractors
    Last Post: 01-05-2011, 10:57 AM
  3. BX24 wont start and wont shut off
    By Johndeere3720 in forum Kubota Owning/Operating
    Last Post: 03-25-2010, 07:16 PM
  4. wont start
    By deannawadley in forum New Holland Owning/Operating
    Last Post: 02-19-2010, 04:59 PM
  5. CK 25 wont start
    By drjay9051 in forum Kioti Owning/Operating
    Last Post: 08-27-2008, 06:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
