Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 49
  1. #21
    Member
    Join Date
    Oct 2012
    Posts
    40
    napanee,ont
    ford 8n
    Default Re: 8n wont start
    oh ok lol
  2. #22
    Member
    Join Date
    Oct 2012
    Posts
    40
    napanee,ont
    ford 8n
    this is all i can find
  3. #23
    Member
    Join Date
    Oct 2012
    Posts
    40
    napanee,ont
    ford 8n
    I dont think im looking in the right spot, too new at 8n's
  4. #24
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    last pics were pretty close.
    no sherman.. or at least no arm shifter.
    only other possibilities are a cable shifter with a big knob ont he dash and a metal sheathed cable like a boat throttle cable going into the top right side of the bellhousing. or another maker shuch as F&T or hupp or other, in which case there would be a lever or arm on the RIGHT side of the bellhousing..
  5. #25
    Member
    Join Date
    Oct 2012
    Posts
    40
    napanee,ont
    ford 8n
    8n wont start-imag0357.jpg8n wont start-imag0358.jpg8n wont start-imag0359.jpg8n wont start-imag0360.jpg
    here's each side of the tranny. I'll have to take a look in better light
  6. #26
    Member
    Join Date
    Oct 2012
    Posts
    40
    napanee,ont
    ford 8n
    here's the dash
  7. #27
    Join Date
    Mar 2002
    Posts
    42,133
    Central florida
    average good old 8N
    no aux trannies that I see.. but no biggie. that 4spd crashbox is decently tough as long as you don't try to shift on t he fly..
  8. #28
    Member
    Join Date
    Oct 2012
    Posts
    40
    napanee,ont
    ford 8n
    good to know, I think i got a good deal at 500 bucks
  9. #29
    LD1
    LD1 is offline
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    7,484
    Central Ohio
    Kubota l3400
    Uh....you got a steal @ $500
    Yep, no aux. trannys though. I personally like them cause the sherman gives about double the top speed, and I road my tractors frequently, so road speed is important to me.
    Since you are new to 8n's (and to save you from asking later) here is a quick crash course:
    The lever in the second picture on the side of the rear axle housing (this would be by your right heel) is the PTO on/off lever. Clutch MUST be pressed to turn pto ON, but dont need to be to turn it off.
    In pic 4, the small lever you see tucked up under the seat is draft control override.
    A couple other pointers incase you havent figured it out, the PTO NEEDS to be turning for the 3PH to raise. The pump is driven off the PTO.
    Also, the PTO is transmission driven, so if you ever get something running off the PTO that has a lot of inertia, like a bushhog, and push the clutch to stop, the inertia will keep driving you. You can buy an aftermarket overrunning clutch to prevent this if you ever decide to bushhog with it.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 105 and 306 cutters
    JD 261 3PH mower
    3 Homemade wood hauling trailers
    Dolmar 7900
    Dolmar 6400 84cc ported BB kit and Muffler Modded
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
    Dolmar 350 "dads"
  10. #30
    Member
    Join Date
    Oct 2012
    Posts
    40
    napanee,ont
    ford 8n
    Default
    Thanks for the info I was wondering how the the 3 point worked
Similar Threads
  1. another 8n that wont start.
    By Adj100 in forum Ford Vintage Tractors
    Last Post: 08-30-2012, 11:54 AM
  2. 9N wont start
    By wadeschields in forum Ford Vintage Tractors
    Last Post: 01-05-2011, 10:57 AM
  3. BX24 wont start and wont shut off
    By Johndeere3720 in forum Kubota Owning/Operating
    Last Post: 03-25-2010, 07:16 PM
  4. wont start
    By deannawadley in forum New Holland Owning/Operating
    Last Post: 02-19-2010, 04:59 PM
  5. CK 25 wont start
    By drjay9051 in forum Kioti Owning/Operating
    Last Post: 08-27-2008, 06:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
