Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 49
  1. #1
    Bronze Member kool cat's Avatar
    Join Date
    Oct 2012
    Posts
    56
    napanee,ont
    ford 8n
    Default 8n wont start
    hey all
    new to the site and new to 8n's.
    I picked up a 1950 to 52 8n, it hasn't ran in two years. when i bought it the guy told me the it didnt have a spark. so i clean thing up so i can see everything and fixed some wires with bad connectors. then i couldnt get the starter to work so i got a new starter solenoid. and still didnt work.
    I called my father in-law cause he has a 46 8n we found that the battery was no good boosted it and it rolled over. so we still had no spark at the plugs. it was supost to have a new coil and point and condensor, then i got new plugs. And still nothing.
    So we had one more person come over and look everything over. so I bought a new coil and condensor cause we didnt know if it was rebuilt right and didnt know if the parts were any good. we rebuilt the distributor and still no spark.
    so its a 1950 to 52 ford 8n with a side distributor.
    Anyone have any ideas?
  2. #2
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    175
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    Did you check your on/ off switch, check voltage to the switch and check voltage out of switch, if you have voltage coming out of the switch then check that you have voltage going to the coil, if your gettin voltage to the coil check and see if your getting it to the points
  3. #3
    Platinum Member tmajor's Avatar
    Join Date
    Oct 2007
    Posts
    684
    NE PA
    '53 Ford NAA Jubilee, 2010 MF 1529, Woods ZTR MZ1952, National Mower sickle bar circa 1963
    Default Re: 8n wont start
    The voltage at the points, should drop to (0) volts (ground), when the points close.
    "There's gotta be a better way!"
  4. #4
    Join Date
    Oct 2012
    Posts
    56
    napanee,ont
    ford 8n
    yup getting power to the coil and the distributor and that is where we are losing it.
  5. #5
    Join Date
    Oct 2007
    Posts
    684
    NE PA
    I'm not understanding "losing it". If the wire is hooked up and you are measuring voltage. "it's there". If you have the wire off and have voltage and don't after hooking it up, there is a short inside or the points are closed.
  6. #6
    Join Date
    Oct 2012
    Posts
    56
    napanee,ont
    ford 8n
    that is what we are thinking. somethings not right.
    how can you have the power at the distributor then nothing. how can that be?
  7. #7
    Join Date
    Oct 2007
    Posts
    684
    NE PA
    The points are the last element in the low voltage circuit of the ignition. One portion of the points is tied to ground, the other portion is tied to the low voltage wire from the coil. When the points close, the low voltage wire from the coil is grounded through the closed points.
  8. #8
    Join Date
    Oct 2012
    Posts
    56
    napanee,ont
    ford 8n
    is there a way check for the power in side the distributor?
  9. #9
    Join Date
    Oct 2007
    Posts
    684
    NE PA
    Remove the low voltage wire going to the distributor. replace it with a wire you can touch to ground. Each time you touch it to ground, you should get fire from the high tension wire on the coil .. to ground. Do you have the battery in the correct way? I believe the original wiring was with a (+) positive ground.
  10. #10
    Join Date
    Oct 2007
    Posts
    684
    NE PA
    There should be power on the one segment of the points .. if they are open.
Similar Threads
  1. another 8n that wont start.
    By Adj100 in forum Ford Vintage Tractors
    Last Post: 08-30-2012, 12:54 PM
  2. 9N wont start
    By wadeschields in forum Ford Vintage Tractors
    Last Post: 01-05-2011, 11:57 AM
  3. BX24 wont start and wont shut off
    By Johndeere3720 in forum Kubota Owning/Operating
    Last Post: 03-25-2010, 08:16 PM
  4. wont start
    By deannawadley in forum New Holland Owning/Operating
    Last Post: 02-19-2010, 05:59 PM
  5. CK 25 wont start
    By drjay9051 in forum Kioti Owning/Operating
    Last Post: 08-27-2008, 07:03 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
