Results 1 to 4 of 4
11-06-2012, 04:38 PM #1New Member
- Join Date
- Nov 2012
- Posts
- 1
- Location
- LELAND NC
- Tractor
- 1952 FORD 8N
1952 ford 8n the lift works when it wants to. what can i do
same as th title.
11-06-2012, 05:50 PM #2Elite Member
- Join Date
- Jun 2011
- Posts
- 2,517
- Location
- NE Oklahoma
- Tractor
- MF 230 and Mitsubishi D2000
Re: 1952 ford 8n the lift works when it wants to. what can i do
Welcome from Oklahoma. You might want to post this under "Owning/Operating" with some information, such as when did it start doing this, is it only when machine is cold, if you've changed fluid, etc. With no information given you'll have a harder time getting food information in return.
KenMassey Ferguson 230
Mitsubishi D2000
11-06-2012, 06:02 PM #3Epic Contributor
- Join Date
- Mar 2002
- Posts
- 42,066
- Location
- Central florida
- Tractor
- ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
as you know, the pto must be operating for the hyds to operate.
if the oil is milky and dirty, the control valve can stick.
if you remove the round cover where the dipstick is, there is a long rod from t he top cover to the pump. as you move the 3pt lever, this rod moves the control valve ina d out of hte pump. if the oil is gritty and dirty, the valve may not move fully in or out.
post back some more info
11-09-2012, 01:40 PM #4Administrator
- Join Date
- Jul 2010
- Posts
- 2,138
- Location
- San Diego, California
- Tractor
- None
Welcome to TBN
I moved your thread to the Ford Vintage Tractors forum.Briana
TBN Administrator
Similar Threads
1952 Ford 8N won't start
By rickdmedina in forum Parts/RepairsReplies: 59Last Post: 10-09-2012, 09:14 PM -
1952 8N Ford
By Laurieshood in forum Ford Vintage TractorsReplies: 7Last Post: 06-05-2012, 04:18 PM -
1952 ford 8n
By smitty1127 in forum Private Party AdsReplies: 11Last Post: 02-18-2011, 10:55 PM -
Oil & Fuel 1952 Ford 8N fuel problem?
By denden1960 in forum New Holland Owning/OperatingReplies: 5Last Post: 05-04-2010, 01:25 PM -
1952 ford 8N restoration
By Soundguy in forum Ford Vintage TractorsReplies: 12Last Post: 08-23-2002, 05:08 PM
