Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. #21
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: Ford 841D - first tractor project (modifications)
    it DEFFINEATELY could be the return line leaking unde rthe VC
    i'd normally look at shaft / umbrella seals in a pump.. but if yours is rebuilt.. then.. look at the stem in the tank and the return line..
  2. #22
    Join Date
    Jun 2010
    Posts
    86
    North Texas
    Ford 841D FEL, Ford 881D, Ford 841L
    I am planning to remove valve cover this weekend.
    I have all the repair manuals & parts book, but there is no mention
    of checking the return line - what to look for & how to
    spot the problem. (I used the forums to even get good
    Info. As to the possible issue). If the internal fuel return line is the
    issue, is this a straight up replacement or can they normally be repaired?
  3. #23
    Join Date
    Jun 2010
    Posts
    86
    North Texas
    Ford 841D - first tractor project (modifications)-image.jpgI did squeeze in the time to tack the driver's
    side panel together this pm. The two sides are
    Matching up nicely. I'm going to try & clean it
    up and maybe get a little primer on it just to
    Keep rust off. Ford 841D - first tractor project (modifications)-image.jpgFord 841D - first tractor project (modifications)-image.jpgFord 841D - first tractor project (modifications)-image.jpgFord 841D - first tractor project (modifications)-image.jpg
    Sorry for the poor quality pictures, I'm not very good
    With these mobile devices.
    Last edited by bennevis; 02-21-2013 at 08:28 PM. Reason: I can't operate these dang phones!
  4. #24
    Join Date
    Jun 2010
    Posts
    86
    North Texas
    Gonna get this hood sorted out properly & primed this weekend.Ford 841D - first tractor project (modifications)-004.jpgFord 841D - first tractor project (modifications)-006.jpg
  5. #25
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,797
    Looks great.
  6. #26
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    139
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    Looks good, could you post a pic of how you have the rear ROPS attached to the rear, I want to add this to my tractor and I just want to see how other people have done it
  7. #27
    Join Date
    Mar 2002
    Posts
    42,111
    Central florida
    rops attach to the rear axle at the fender bolt locations.
  8. #28
    Elite Member
    Join Date
    Apr 2008
    Posts
    2,797
    Quote Originally Posted by Varmint1 View Post
    http://www.tractorbynet.com/forums/m...structure.html
  9. #29
    Join Date
    Jun 2010
    Posts
    86
    North Texas
    I built subframe from front to back & bolted it every place the housings came together. I also bolted a cradle underneath each. I did attach the back end at fender bolts, but also added a cradle bar underneath. Everything is tied together, I don't know if the set-up is proper, but it is pretty stout. I don't have any photos with me, but I will take some tomorrow. If you look at my first or second post, there may be a few there.
  10. #30
    Join Date
    Jun 2010
    Posts
    86
    North Texas
    These were in the thread earlier, I just copied them. They are hard to make out, will get better ones...Ford 841D - first tractor project (modifications)-img_4533.jpgFord 841D - first tractor project (modifications)-img_4535.jpgFord 841D - first tractor project (modifications)-img_4537.jpg(the bit next to subframe in 2nd photo is just a return for rear remotes).
Similar Threads
  1. My Ford 4500 project
    By ohbuckhunter in forum Projects
    Last Post: 04-08-2012, 05:27 PM
  2. Ford 841D ROPS
    By Super_Chief in forum Safety
    Last Post: 09-07-2008, 10:51 PM
  3. My tractor modifications
    By SLM1294 in forum Customization
    Last Post: 07-17-2008, 04:56 PM
  4. A bit off topic .... Tractor modifications
    By nails_n_glue in forum John Deere Owning/Operating
    Last Post: 09-06-2007, 08:44 AM
  5. Tractor modifications
    By centex in forum Owning/Operating
    Last Post: 10-10-2003, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
