Page 4 of 10 FirstFirst 1234567 ... LastLast
Results 31 to 40 of 100
  1. #31
    Join Date
    Sep 2012
    Posts
    218
    hawesville
    600 ford
    Default Re: Ford 841D - first tractor project (modifications)
    that is amazing work , i would like to have mine like that .
  2. #32
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Ford 800, Ford 841D, Ford 841D Loader/backhoe, Ford 881D, Ford 851L, Farmall Super H
    I've been working off and on the last couple months on this tractor & since the internal hydraulics were weak (I wasn't sure at the time if it was the pump or the cylinder etc...). I have decided to make this tractor a dedicated TLB. (I've had the backhoe for a year & just now getting to it). Valves are in good shape on the BH, but my subframe is homemade, so I have had to modify the hook-up & that is still in progress.
    It is still going to be removable, but I have no plans of doing that unless necessary. I already have a front mounted pump 23 gpm that I use with the MF 200 loader, so I have removed all internal hydraulics, boxed them in a Rubbermaid container & fabricated cover plates for all of it. I have a 5 gallon reservoir on the loader, but the specs for 713 call for about 12 gallons. I wanted to use the internal sump (and maybe rear axle)? for a reservoir. I know I've read about this being done, but I can't find any info. when I need it. I have ideas for plumbing it - I just wanted advice on the internal sump & maybe the rear housing as main res. There is no leakage between trans. & hydraulics. Presently, there is in rear end, because I removed PTO components for later use as well. (Built a cover plate for the side).
    I've got some pictures of what I've done - any help on this project appreciated!
    Ford 841D - first tractor project (modifications)-may-4th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-4th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-4th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-4th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-4th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-4th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-5th-backhoe-work-010-aFord 841D - first tractor project (modifications)-may-6th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-8th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-8th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-17th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-17th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-21st-2013-backhoe-disasterFord 841D - first tractor project (modifications)-may-21st-2013-backhoe-disasterFord 841D - first tractor project (modifications)-may-21st-2013-backhoe-disasterFord 841D - first tractor project (modifications)-april-30th-2013-backhoe-workFord 841D - first tractor project (modifications)-april-30th-2013-backhoe-workFord 841D - first tractor project (modifications)-april-30th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-1-20113-backhoe-workFord 841D - first tractor project (modifications)-may-1-20113-backhoe-work
  3. #33
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    SoundGuy has helped me figure out the plumbing (using my old Hyd. sump as add-on reservoir). The main-frame is now modified to fit the tractor & it can be removed if necessary, but after the work is completed, I hope to seldom remove BH, FEl, or sub-frame. the 713 seemed to have issues with the main frame cracking (most all I have seen were patched), so I incorporated 1/2 plating down each side & 1/2 plating welded to the back of cab w/6 bolts on each side for support.
    A little more bracing to do on the front side, but nearly finished with that. There is only going to be one seat - it is going to run on tracks (channel) & run up angle to backhoe controls (car seatFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-workFord 841D - first tractor project (modifications)-may-25th-2013-backhoetractor-work motor). Then spin around & raise it to a comfortable level. (It kinda works like a ski lift). Hope to get control valve finished & start putting things back together.
  4. #34
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    175
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    Looking good, how much more before its finished?
  5. #35
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Quote Originally Posted by allen6634 View Post
    You are very kind, I hope it will turn out the way I imagine it....
  6. #36
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Varmint,
    I hope to have the BH back operational by mid-June....(if everything goes smoothly). But as far as finished, LOL - at the speed I work, it could be this time next year...especially if I keep modifying the modifications....!
  7. #37
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,712
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    keep the pics coming!
    souNdguy
    sent from my NOKIA LUMIA
  8. #38
    Join Date
    Sep 2012
    Posts
    218
    hawesville
    600 ford
    wow this just keeps getting better very good attention to detail, very impressed with the hood.
  9. #39
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    After looking at the options for tapping into the sump for additional reservoir, I figured my best bet (shortest distance & largest opening) was to fabricate a blank plate cover to replace the existing relief valve cover. I figure I can weld black pipe with exactly the angle & drop needed to be a straight shot into main res. I also plan to use larger diameter pipe than the intake line to help assist flow (I've been reading the Womack hydraulics books for ideas & they recommend larger pipe). BTW, if you are like me & struggle with tractor hydraulics - Womack's books can really help, especially understanding basic concepts.
    I've added a few pictures of the relief valve & it's cover plate (excuse the mess in there, it's getting cleaned up).
    I also experimented with paint, so I did a wee bit of priming as well. Here's a few of those pictures as well. But, I must confess I have batted around several ideas for paint scheme & after this first attempt - I have decided to go back closer to my original paint scheme. (It isn't traditional...I hope that won't offend anyone). I just don't have the knowledge or expertise to get the paint colors to match original, so I'm going to be doing some more tests on the paint....but I don't want to get sidetracked on that too much yet.
    Ford 841D - first tractor project (modifications)-may-28th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-28th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-28th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-28th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-28th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-28th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-28th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-27th-2013-tractor-workFord 841D - first tractor project (modifications)-may-27th-2013-tractor-workFord 841D - first tractor project (modifications)-may-27th-2013-tractor-workFord 841D - first tractor project (modifications)-may-27th-2013-tractor-work
  10. #40
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Just to clarify, I'm cutting a hole in the blank plate to weld the pipe! The original & the relief valve are stored for future use.
Similar Threads
  1. My Ford 4500 project
    By ohbuckhunter in forum Projects
    Last Post: 04-08-2012, 05:27 PM
  2. Ford 841D ROPS
    By Super_Chief in forum Safety
    Last Post: 09-07-2008, 10:51 PM
  3. My tractor modifications
    By SLM1294 in forum Customization
    Last Post: 07-17-2008, 04:56 PM
  4. A bit off topic .... Tractor modifications
    By nails_n_glue in forum John Deere Owning/Operating
    Last Post: 09-06-2007, 08:44 AM
  5. Tractor modifications
    By centex in forum Owning/Operating
    Last Post: 10-10-2003, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
