Page 5 of 10 FirstFirst ... 2345678 ... LastLast
Results 41 to 50 of 100
  1. #41
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Ford 800, Ford 841D, Ford 841D Loader/backhoe, Ford 881D, Ford 851L, Farmall Super H
    Default Re: Ford 841D - first tractor project (modifications)
    Thanks! That has been my favorite thing to do so far. I have more scrap sheet metal & I am making parts for the cab - I want it to at least look like Ford lines & style...
    Quote Originally Posted by allen6634 View Post
    wow this just keeps getting better very good attention to detail, very impressed with the hood.
  2. #42
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    if you remove the oe relief. where are you getting relief from?
    souNdguy
    sent from my NOKIA LUMIA
  3. #43
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Quote Originally Posted by Soundguy View Post
    SoundGuy, I believe I could leave the OE relief valve in place & still use the intake opening, but it wouldn't function as relief because it is no longer connected to a pressure line. Everything under the lift cover is only functioning as a reservoir - both intake & pressure lines are capped off where the tube assembly bolts to the transmission housing. I am using an inline relief valve on the pressure side of crankshaft pump. The center housing will only have a return line from BH.Ford 841D - first tractor project (modifications)-may-16th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-17th-2013-backhoe-workFord 841D - first tractor project (modifications)-may-17th-2013-backhoe-work
    Surplus center has several that I am looking at. The intake line from loader reservoir & pressure line to selector valve are presently hose, but I am replacing the hoses with rigid line (mainly) & there seems to be plenty of good spots for the relief valve.
  4. #44
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ah.. no 3pt hyds or top cover remotes.
    got ya.
    no prob
    souNdguy
  5. #45
    Join Date
    May 2012
    Posts
    162
    New Martinsville, WV
    1970 MF-135 and 1951 Ford 8N
    I like that anvil. Is it an old one?
  6. #46
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    That is a great anvil, it's been in the family as long as I have been around. I did some research a few years back - can't remember much now, but super to work with. I don't know what steel they used, but all the pounding and bending etc... & not a dent on it. I've never seen another one like except on the internet.
  7. #47
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Well, I've been away for a bit - life gets in the way & slows you down...but, I do have some updates. (and a few pictures). First, after many design ideas to add the old sump as add-on reservoir, I looked at the issue from every angle - old loader reservoir with who-knows-what inside & it's small to boot. I decided to build a completely new reservoir for both loader & backhoe.
    It fits under the backhoe mainframe, holds just under 20 gallons (6 more than required) and I am using two sight gauges (instead of dipstick) - using hard line on both the intake & pressure until the last 8 inches before connections, and that will be hose.
    Since I started using this electrolysis process, it has proven so effective, I've ended up moving my way up the tractor - piece by piece. All the cylinders are rebuilt & I am working on the lines for the BH tomorrow. This is a bit short on details, but hopefully, I will have time to post more in depth. (Including the final solution to diesel in the crankcase)! The standpipe had come loose - no breaks, no holes - it just had a very small bit of braze on it & that held for 50 years ad popped off. It's at the radiator shop now, hopefully that will be resolved by Monday. So, here's a little of the progress:
    Ford 841D - first tractor project (modifications)-may-30th-2013-tractor-workFord 841D - first tractor project (modifications)-may-30th-2013-tractor-workFord 841D - first tractor project (modifications)-may-31st-2013-tractor-backhoeFord 841D - first tractor project (modifications)-may-31st-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-3rd-2013-tractor-workFord 841D - first tractor project (modifications)-june-3rd-2013-tractor-workFord 841D - first tractor project (modifications)-june-4th-2013-tractor-workFord 841D - first tractor project (modifications)-june-4th-2013-tractor-workFord 841D - first tractor project (modifications)-june-5th-tractor-backhoe-workFord 841D - first tractor project (modifications)-june-6th-2013-tractor-workFord 841D - first tractor project (modifications)-june-6th-2013-tractor-workFord 841D - first tractor project (modifications)-june-6th-2013-tractor-workFord 841D - first tractor project (modifications)-june-7th-2013-tractor-workFord 841D - first tractor project (modifications)-june-7th-2013-tractor-workFord 841D - first tractor project (modifications)-june-7th-2013-tractor-workFord 841D - first tractor project (modifications)-june-7th-2013-tractor-workFord 841D - first tractor project (modifications)-6-14-2013-tractor-backhoeFord 841D - first tractor project (modifications)-6-14-2013-tractor-backhoeFord 841D - first tractor project (modifications)-6-14-2013-tractor-backhoeFord 841D - first tractor project (modifications)-6-14-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-15-2013-tractor-workFord 841D - first tractor project (modifications)-june-16-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-16-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-17-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-17-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-18th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-21-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-21-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-21-2013-tractor-backhoeFord 841D - first tractor project (modifications)-june-21-2013-tractor-backhoe
  8. #48
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Since I started using this electrolysis process, it has proven so effective, I've ended up moving my way up the tractor - piece by piece. All the cylinders are rebuilt & I am working on the lines for the BH tomorrow. This is a bit short on details, but hopefully, I will have time to post more in depth. (Including the final solution to diesel in the crankcase)! The standpipe had come loose - no breaks, no holes - it just had a very small bit of braze on it & that held for 50 years and popped off. It's at the radiator shop now, hopefully that will be resolved by Monday. The photos are a bit random, but here's a little of the progress:
  9. #49
    Silver Member Varmint1's Avatar
    Join Date
    Jun 2012
    Posts
    175
    Deville,La
    JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
    Default
    Looking good, won't be long and you'll be digging.
  10. #50
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    i agree!
    souNdguy
Similar Threads
  1. My Ford 4500 project
    By ohbuckhunter in forum Projects
    Last Post: 04-08-2012, 05:27 PM
  2. Ford 841D ROPS
    By Super_Chief in forum Safety
    Last Post: 09-07-2008, 10:51 PM
  3. My tractor modifications
    By SLM1294 in forum Customization
    Last Post: 07-17-2008, 04:56 PM
  4. A bit off topic .... Tractor modifications
    By nails_n_glue in forum John Deere Owning/Operating
    Last Post: 09-06-2007, 08:44 AM
  5. Tractor modifications
    By centex in forum Owning/Operating
    Last Post: 10-10-2003, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
