Page 8 of 10 FirstFirst ... 5678910 LastLast
Results 71 to 80 of 100
  1. #71
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Ford 800, Ford 841D, Ford 841D Loader/backhoe, Ford 881D, Ford 851L, Farmall Super H
    Default Re: Ford 841D - first tractor project (modifications)
    Quote Originally Posted by Soundguy View Post
    extra oil means less heat.
    I kept reminding myself of that very thing once I realized my mistake! I don't know how much difference it makes, but that's a pretty big jump in capacity (almost double). Thx for suggesting the add-on tank in the 1st place. Now, it's the only tank!
  2. #72
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    it's the best way to do it.. really. and yeah.. the larger tank has more surface area to radiate heat, plus more oil volume.. all win-win..
    souNdguy
    sent from my NOKIA LUMIA
  3. #73
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Being a bit naive & overly-optimistic, I underestimated the time it would take to finish up the smaller items & get the boom back into place. (I have decided to make sure everything else necessary to the BH functioning properly are all complete & double-checked before gathering buddies to help install the boom, so I still may be another few...well, no need to set a time-frame)!
    Along with life's constant diversions & distractions - the heat has been pretty intense here in North Texas, so forgive my slow progress - I promise I am putting in all the time I can. I have made a couple more revisions in the plumbing (using old water-hose in every configuration), but I feel confident these few changes will be the last. I have both return lines completed, site gauge installed, return filter, & a few other gadgets on the reservoir and hydraulic system.
    Ford 841D - first tractor project (modifications)-july-13th-2013-013-jpgFord 841D - first tractor project (modifications)-july-13th-2013-014-jpgFord 841D - first tractor project (modifications)-july-13th-2013-017-jpgFord 841D - first tractor project (modifications)-july-13th-2013-018-jpgFord 841D - first tractor project (modifications)-july-13th-2013-019-jpgFord 841D - first tractor project (modifications)-july-15-2013-004-jpgFord 841D - first tractor project (modifications)-july-16-2013-tractor-013-a
    I am proud to say that the original BH return fit perfectly in place even with all the modifications to the main frame. I have been experimenting with brackets to support the steel return pipes and hose clamps for the rubber lines. (the clamps I've found online are great, but they just won't work for several places I need them.
    Ford 841D - first tractor project (modifications)-hose-suport-jpgFord 841D - first tractor project (modifications)-hose-suport1-jpgFord 841D - first tractor project (modifications)-hose-support2-jpgFord 841D - first tractor project (modifications)-original-tubing-return-fit3-jpg
    Finally, I spent time figuring out how to build solid brackets for my front fenders - it was pretty easy (I did look at as many pics as I could find, including NH site, but the clincher was figuring out a practical way to attach to the bottom of the spindles). If there is already a tried and true method, please let me know, because it took...a while for the light bulb to go on! Anyway, here's some progress, I have the whole weekend (most time in weeks), so maybe things will really start moving! Thanks!Ford 841D - first tractor project (modifications)-july-19-2013-007-jpgFord 841D - first tractor project (modifications)-july-18th-2013-002-jpgFord 841D - first tractor project (modifications)-july-18th-2013-004-jpgFord 841D - first tractor project (modifications)-july-16-2013-tractor-009-a
  4. #74
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    nice deal!
    souNdguy
  5. #75
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Thanks SG! I got a lot done today, but haven't taken many pictures yet. (maybe in AM). I've got a few of work on the swing cylinders & checking to make sure everything back there lined up with new tank & all. (Thankfully, it did)! So, here's a few & I'll try to post some tomorrow night.
    Please overlook the multicolored...everything - all part of experimenting with the paint.
    Ford 841D - first tractor project (modifications)-all-lined-up-unbelievable-jpgFord 841D - first tractor project (modifications)-all-lined-up-unbelievable-1-aFord 841D - first tractor project (modifications)-all-lined-up-unbelievable-2-aFord 841D - first tractor project (modifications)-bh-tubing-cut-rewelded-hose
    I have one swing cylinder 1/2" longer (replacement?), so i had to push the trunion back 1/2" on starboard side & added a notched 1/4' piece of angle iron to help hold them steady. (I'm going to add another to bottom trunions.Ford 841D - first tractor project (modifications)-angle-iron-notched-bracing1-jpgFord 841D - first tractor project (modifications)-angle-iron-notched-bracing2-jpgFord 841D - first tractor project (modifications)-bottom-supports-added-steel-jpgFord 841D - first tractor project (modifications)-cylinders-notched-angle-iron-jpgFord 841D - first tractor project (modifications)-lower-support-added-steel-jpg
  6. #76
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    could be a repalced cyl. I have a kobelco cyl one one of my loaders in place of an old ford cyl..e tc.
    souNdguy
  7. #77
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    The best laid plans of mice and men...are often delayed! My Fall and winter were completely consumed with other projects that were "have to's!" I've been back on the tractor for about 3 weeks now & I wanted to show some progress. I'll try to catch up in the next few days.Ford 841D - first tractor project (modifications)-august-19-2013-002-jpgFord 841D - first tractor project (modifications)-august-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-august-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-august-20th-2013-tractor-backhoeFord 841D - first tractor project (modifications)-august-21st-2013-011-jpgFord 841D - first tractor project (modifications)-august-21st-2013-013-jpgFord 841D - first tractor project (modifications)-august-22-2013-012-jpgFord 841D - first tractor project (modifications)-august-22-2013-013-jpgFord 841D - first tractor project (modifications)-august-22-2013-022-jpgFord 841D - first tractor project (modifications)-august-22-2013-008-jpgFord 841D - first tractor project (modifications)-august-24th-2013-054-jpgFord 841D - first tractor project (modifications)-august-24th-2013-006-jpgFord 841D - first tractor project (modifications)-august-24th-2013-007-jpgFord 841D - first tractor project (modifications)-img_1220-jpgFord 841D - first tractor project (modifications)-img_1258-jpg
  8. #78
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    A few more...Ford 841D - first tractor project (modifications)-img_1779-jpgFord 841D - first tractor project (modifications)-img_1780-jpgFord 841D - first tractor project (modifications)-img_1781-jpgFord 841D - first tractor project (modifications)-img_1902-jpgFord 841D - first tractor project (modifications)-img_1903-jpgFord 841D - first tractor project (modifications)-img_1922-jpgFord 841D - first tractor project (modifications)-img_1927-jpgFord 841D - first tractor project (modifications)-img_2020-jpgFord 841D - first tractor project (modifications)-img_2030-jpgFord 841D - first tractor project (modifications)-img_2120-jpgFord 841D - first tractor project (modifications)-img_2122-jpgFord 841D - first tractor project (modifications)-img_2125-jpgFord 841D - first tractor project (modifications)-img_2128-jpg
  9. #79
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    nice pics thanks!
    souNdguy
  10. #80
    Join Date
    Jun 2010
    Posts
    129
    North Texas
    Ford 841D - first tractor project (modifications)-img_2411-jpg[/ATTACH]Ford 841D - first tractor project (modifications)-img_2426-jpg[/ATTACH]Ford 841D - first tractor project (modifications)-img_2407-jpgFord 841D - first tractor project (modifications)-img_2408-jpg
    Attached Thumbnails Attached Thumbnails Ford 841D - first tractor project (modifications)-imgp0064-jpg
Similar Threads
  1. My Ford 4500 project
    By ohbuckhunter in forum Projects
    Last Post: 04-08-2012, 05:27 PM
  2. Ford 841D ROPS
    By Super_Chief in forum Safety
    Last Post: 09-07-2008, 10:51 PM
  3. My tractor modifications
    By SLM1294 in forum Customization
    Last Post: 07-17-2008, 04:56 PM
  4. A bit off topic .... Tractor modifications
    By nails_n_glue in forum John Deere Owning/Operating
    Last Post: 09-06-2007, 08:44 AM
  5. Tractor modifications
    By centex in forum Owning/Operating
    Last Post: 10-10-2003, 12:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
