Results 1 to 9 of 9
  1. #1
    New Member
    Join Date
    Mar 2013
    Posts
    3
    Franklin, Ky
    861 Powermaster
    Default 861 won't lift high enough
    My 861 won't lift as high as it should and it goes lower than it should. This started after my grandfather tried to move a roll of hay in real cold weather. What's wrong? My grandfather used it this way for years but I would like to fix it. Can't even lift grader blade high enough to drive up on trailer.
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 861 won't lift high enough
    does it change any if you mess with the draft control?
    it's very possible the cam pin ( and maybee cam ) is worn and in need of repalcement, and the internal linkage adjusted using the alternate adjustment method in the shop manual without the use of the nuday tools.
  3. #3
    New Member
    Join Date
    Mar 2013
    Posts
    3
    Franklin, Ky
    861 Powermaster
    Nothing changes with draft control. Thanks for reply. I've had a few people say there was an internal adjustment. I just ain't got that far yet. Got a shop manual somewhere. I'll find it and on a warmer day I'll give it a look. Thanks again.
  4. #4
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    plan on that am pin.. i rearely see one that DOES NOT need it.
  5. #5
    Join Date
    Jan 2011
    Posts
    717
    Westmoreland County PA
    Fords
    Mine does not lift high enough, but if I hold up the draft lever it lifts much higher. What does this mean?
  6. #6
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    just like I said in post #2
    plan on a cam pin.. maybee cam reweld and grind.. and then linkage adjustment using alternate methods in the shop manual without the use of the nuday tools.
    most time the cam wears in profile leaving you a witness mark if you weld it up and grind it down.
  7. #7
    Join Date
    Jan 2011
    Posts
    717
    Fords
    Ok thanks. Since the OP's situation did not change with the draft lever, I thought that maybe we had two different problems.
  8. #8
    Member petra79's Avatar
    Join Date
    Aug 2009
    Posts
    46
    N.W. Ind
    Ford 861 - Farmall C
    Hopefully going to finally get that done on my 861 after the tilling is done this spring. I'm sure you'll be hearing from me Chris.
  9. #9
    Join Date
    Mar 2002
    Posts
    52,748
    Central florida
    for you.. it will be easy....you've got some help with the lifting.. which is generally hta hardest part to R&R the 00/01 top cover..
Similar Threads
  1. Ford 861 lift problems
    By tjsmith in forum Hydraulics
    Last Post: 12-29-2012, 01:35 PM
  2. How high will a 3 pt lift
    By Dan Hunter in forum John Deere Owning/Operating
    Last Post: 05-25-2012, 03:44 PM
  3. Rear Finish Mower High Lift Blades
    By catdozer in forum Attachments
    Last Post: 03-28-2012, 09:54 PM
  4. How high should my tractor lift these?
    By dantegy in forum Attachments
    Last Post: 06-29-2008, 06:42 PM
  5. high-lift jack
    By snapper in forum Owning/Operating
    Last Post: 02-01-2003, 11:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
