Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    Mar 2013
    Posts
    11
    Bradenton ,Fl.
    Ford /Golden Jubilee
    Default 53 jube
    Bought a 53 golden jubilee that has been sitting for a few yrs. It has a few issures i'll fix them one @ a time. 1 st rear wheels have a lot of side to side play in them. I have IT 19 man, mst parts man, and owners manual. I just need to know where to start .
  2. #2
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: 53 jube
    start?
    check motor condition.. if it looks like it's gonna run.. no windows. has good comp and oil pressure.. start working onthe rest.
    rear has side-side play? hubs and axles. hopefully can get by with just new hubs. they are still pretty cheap. probaly 75$ now.. used to be 50.. etc..
    do a complete fluid service.
    engine.. i'd run 15w40.. spin on filter is a motorcraft fl1a / fram ph8a / supertech sta8 etc. napa 1452, 1515, etc.
    cartridge is a napa 1004 or fram ch6pl
    hyds trans and diffy CAN take all the same fluid, utf meeting m2c134 spec. 9 most house brand utf's meet this.. just check ).
    or utf in the hyds.. and 80w90 in the trans and diffy.
    air preather takes a half quart of crankcase oil, after you clean the media.
    trans fil is by shifter.. plug on right side by running board near foot for level.
    hyds fill under seat under left thigh.. has dipstick in round cover.. um.. right side.
    diffy fill behind seat, under right but cheek.. etc. pipe plug in back of left axle trumpet....
    do hubs before ya service her.. might need a pto seal too... easy to pull shaft.. 4 bolts.. just be gentle.. don't buger up the seal between hyds and diffy sump.. so when (if ) you re-stab it.. go easy and center it so you don't hog out the seal...
    IF you split her for a clutch.. deffinately also put in a 3$ trans input shaft seal.. trans input shaft makes a good allign tool if they don't give you the 4$ plastic one with the clutch. if it has a sherman instead of a standard inpuit shaft.. it takes the same seal.. and makes a good tool..
    al 437 plugs.. gapped to .025 points to .025 avoid tisco if you can
    here are some ignition #'s
    NAPA #CS749
    NAPA HEAVY DUTY PIERCED (ventilated) #CS753
    Standard Ignition #FD-8081
    Standard Ignition Blue Streak #FD-8081X (Premium)
    Condensor:
    NAPA #FA66
    Standard Ignition #FD-75
    Standard Ignition Blue Streak #FD75X (Premium)
    Rotor:
    NAPA #FA67
    Standard Ignition #FD-108
    Distributor Cap:
    NAPA #FA352
    Standard Ignition #FD-128
    side mount points hold down screws #8-32 X 3/16
    FORD AUTOMOBILE dealer parts counter. come with built-in lockwasher. p/n 355047-S7 (#8-32 X 0.19)
  3. #3
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Default Re: 53 jube
    oh yeah.. get some cheap dex 3 / merc atf and soak the engine cyls in it.. will help loosen the rings up...
  4. #4
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: 53 jube
    SG, is all this in your head?
    Murph
  5. #5
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Default Re: 53 jube
    Quote Originally Posted by murphy1244 View Post
    all that was... for sure, so stuff I reference in other posts I have to hit a manual for.. but the 'staple' stuff is all hardwired by now..
  6. #6
    New Member
    Join Date
    Mar 2013
    Posts
    11
    Bradenton ,Fl.
    Default Re: 53 jube
    Got it running last wkend had to rewire it, rebuild carb,clean rust out of gas tank, plugs,points condenser. compression 119 on 1 cyl. 120/121 on other three,started but motor keeps reving up without moving throtle.have to hold throtlef rod forard toward gov. Like I said few issures, just take them one @ time. Thanks SG for info. i didn't know i could find parts local, i have been ordering online. So Start with drums anything in particular to look for. I appreciate your help it's been quite a few yrs sence working on one.
  7. #7
    Join Date
    Mar 2002
    Posts
    52,662
    Central florida
    Default Re: 53 jube
    new drums will be cast.. older were steel.. rarely are they worn out. hubs are still pretty cheap.
    check the friction disc and tension nut/spring onthe throttle bellcrank if the throttle is slipping
Similar Threads
  1. 53 jube repair
    By Bill J 124 in forum Parts/Repairs
    Last Post: 03-08-2013, 06:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
