Results 1 to 10 of 10
  1. #1
    New Member dchap's Avatar
    Join Date
    Mar 2013
    Posts
    6
    Wetumpka, AL
    1951 Ford 8n
    Default Need help identifying this problem...
    I have a 1950 8N that I an repainting. Admittedly, I am no mechanic and I have never done anything like this before. I have parts mostly stripped off and I am prepping for the paint job. Today I noticed water leaking from the engine block. I have attached a picture. It was not leaking before, but I think I must have done it while stripping paint. It was pretty rusty. Anyway, could someone please tell me what that little round thing is in the engine block (there are four of them). Is this a major repair or something a novice like myself could do? Any guidance would be appreciated.
  2. #2
    Gold Member Lou66's Avatar
    Join Date
    Nov 2012
    Posts
    491
    Brazoria county where Texas began
    Deere 990/Montana 5740
    Default Re: Need help identifying this problem...
    freeze plug,, knock it out and replace it.. on that model it's time.. Lou
    "Life is good if beer is cold"
  3. #3
    Join Date
    Mar 2013
    Posts
    6
    Wetumpka, AL
    1951 Ford 8n
    Thanks Lou. I appreciate your helpful response.
  4. #4
    Member Dollar Bill's Avatar
    Join Date
    Dec 2010
    Posts
    43
    Keystone Heights, FL
    48/50 8N, 63 4000 Row Crop NF
    Just to help you out, they're call Welch Plugs and there is somewhat of a technique for installing them.
    The objective is to flatten the Welch plug so that it spreads out and jams in the hole:
    1. Ensure the plug receptacle in the block is squeaky clean.
    2. Coat the block with Loc-Tite and insert the plug. Permatex Form-A-Gasket #1 is a suitable alternate.
    3. Use two ball peen hammers - One as a buck to achieve a flat hammer strike.
    4. The edges of an installed plug may be staked to improve retention.
    5. Again, the goal should be an installed plug that is visually flat.
    6. Use brass Welch plugs if you can find them. They are 1 3/16" diameter.
    While you're at it, it's a fair bet the other plugs are in the same state of rusting out - So may as well do all of them.
    Correct
    Incorrect
    I love anything that turns money into noise!
  5. #5
    Join Date
    Mar 2013
    Posts
    6
    Wetumpka, AL
    1951 Ford 8n
    Thanks Dollar Bill! With my very limited mechanical experience, those are just the kind on instructions I need. I guess I will go ahead and change them all while I am at it. At the risk of sounding dumb, what do you mean when you say, "plug may be staked to improve retention.?" I'm not familiar with the staked reference.
  6. #6
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    42,146
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    core plug. 2$ napa.
    poke a screwdrive thru it with a hammer. twist and pop it out.
    clean hole with steel wool after draining water down past hole.
    then clean hole with a green scrubby.. then a solvent like carb cleaner or alcohol. let dry.
    apply permatex #2 tot he hole ID, and the plug OG, set the plug then peen it to dimple in place.
    5 minte job if ya are slow.
    souNdguy
    sent from my ASUS tablet
  7. #7
    Join Date
    Mar 2002
    Posts
    42,146
    Central florida
    didn't see DB had ya covered.
    he gave ya good info.
    souNdguy
  8. #8
    Join Date
    Dec 2010
    Posts
    43
    "what do you mean when you say, "plug may be staked to improve retention"
    Occasionally, you come across a hole where rust has eroded the plug receptacle to the point of not holding the plug after it's installed.
    Staking in this case means to slightly expand the area adjacent to the mating surface of the plug with a prick punch (envision a row of dots all around the edge of the plug). This will reduce the clearance between the block and plug thereby increasing tension to retain the Welch plug in place.
  9. #9
    Join Date
    Mar 2013
    Posts
    6
    Wetumpka, AL
    1951 Ford 8n
    Default
    That clears that up, DB. Thanks for everything guys. I think I can handle that repair.
  10. #10
    Join Date
    Mar 2002
    Posts
    42,146
    Central florida
    another trick is to clean the hole ID, and then get out your plumbers torch set and solver solder and acid flux and add some solder around the id. do it like sweating copper. it will wet and spread a small film around the hole. polish the id of that and you can get some more retention out of it too. Heck.. i've seen people solder in a brass plug that would not hold due to so much rust pitting. not my choice of repairs. but better than a junked block mind you. there are other more drastic optons too.. but you probbaly wo't even need to stake...
    souNdguy
Similar Threads
  1. Identifying bx pto kit
    By RDG in forum Kubota Buying/Pricing
    Last Post: 04-04-2012, 02:23 PM
  2. Loader 400CX Loader Help identifying problem?
    By USMC2531 in forum John Deere Owning/Operating
    Last Post: 07-06-2011, 11:25 AM
  3. Help identifying
    By cef2lion in forum 2-Wheeled Tractors
    Last Post: 07-19-2010, 08:47 AM
  4. Need help identifying
    By Lee2010 in forum General Lawn & Garden
    Last Post: 09-07-2009, 04:22 PM
  5. Need help identifying
    By Degree in forum Chinese Tractors
    Last Post: 07-02-2004, 11:07 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
