4 speed input shaft 1959 641
   / 4 speed input shaft 1959 641 #1
kprat
parsons,tn
ford 641 workmaster
Have a 1959 ford 641 tractor< have separated tractor to repair noise in transmission.Found brgs down on input shaft and front main shaft brg, question is can you replace race in back of input shaft?
   / 4 speed input shaft 1959 641 #2
I don't believe you can. I think you would have to replace the shaft. Is it a 10 or 15 spline shaft?
Kirk
Thanks Kirk it is a 15 spline, found something on youtube about machining one since my reply. Thanks Ken
   / 4 speed input shaft 1959 641 #4
that year would be fine spline. unless of course some's been in there.. etc.
   / 4 speed input shaft 1959 641 #5
Yes I'm sure you could have it machined and use an oversize bearing or maybe have it machined to accept a new race.
Chris, off the top of my head I was thinking it was '59 for the 10 to 15 spline but it was '58 X01. Although easy enough to switch things around if somebody wants too.
Kirk
   / 4 speed input shaft 1959 641 #6
yup. I've seen some inconsistencies in break points. but those could have been exagerated to other people being inside the tranny too! :)
