Well, I was able to get all 6 post holes dug tonight without mishap. I need to learn how to get the hole cleaner though. I noticed that on about 3 of them I left a bunch of loose dirt in the hole that now I'll have to dig by hand. Hopefully the rain holds off until after tomorrow so they don't become too compacted again. The other 3 holes were clean but begun to fill up with water by the time I was done.
I noticed several things using this PHD & my PTO for the first time.
1. My PTO engage does in fact work. Interestingly enough, I dug most of the first hole with the PTO not engaged. I didn't turn it on until right at the very end. However, on the other holes, the auger stopped turning unless the PTO was engaged.
2. My PHD wants to lean to one side or the other depending on how the tractor is resting. I tried to level it using my lift arm leveler, but had limited success.
3. When I lift up even slightly to empty the auger, the tip of the auger wants to swing about wildly in a circular motion roughly 12"-18" in diameter. Beat the tar out of the sides of the holes and I suspect that's why so much soil wanted to fall back in. Is this normal or am I doing something wrong? I had to put the auger down almost immediately to cease the shaking.
4. My lift hydraulics are touchy. It does ok in the lower half of the range, but as I get to the upper half, the lift arms want to take off all the way to the top. Makes the auger swing a lot and it makes the swivels at the end of the PTO-to-gearbox connecting shaft clank around a lot. Can this be adjusted?
Overall, I'd say the fact that I didn't plant the tractor on my first attempt or hit any major roots (I was digging in the woods!) or obstacles makes this first adventure a success.
On a side note, I got my shop manual and the SOS transmission supplement in the mail today from Everydaytractors.com. The pictures are a little dark but hopefully they'll be useful.
