Page 4 of 4 FirstFirst 1234
Results 31 to 40 of 40
  1. #31
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,455
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    Default Re: First time using PTO. Can I get a quick primer?
    concrete or not. friction pile will do ya..
    souNdguy
    sent from my NOKIA LUMIA
  2. #32
    Join Date
    Mar 2014
    Posts
    95
    Blanchester, OH
    1959 Ford 881
    Quote Originally Posted by Soundguy View Post
    Not sure what you mean. (not sure I understand the lingo)
  3. #33
    Super Star Member
    Join Date
    Feb 2006
    Posts
    11,740
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Quote Originally Posted by sleuth View Post
    He probably means friction on the pilings [posts, uprights, etc] will hold them.
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  4. #34
    Join Date
    Mar 2002
    Posts
    52,455
    Central florida
    Yep. a friction pile is a specif ic design. vs say.. end pont pile.. etc..
    here's the 25 cent definition:
    About Friction Piles | eHow
    there's the 2$ definition on piles
    Types of Piles & Classification of Piles in Construction of Foundation
    souNdguy
  5. #35
    Veteran Member the old grind's Avatar
    Join Date
    Jul 2012
    Posts
    1,246
    Mid-Michigan
    NH T-1520 HST, JD 5210 2WD, Case DX26 HST, Terramite T5C
    Interesting to better understand piles as explained in SG's second link. Struck a chord with me because of a fascination with building the Brooklyn Bridge, no less. Why? Built in the days of horse & rope tackle, and ultimately strung with inferior steel cables (excess sulphur in steel way back when ring a bell, or unscrupulous inspectors?) there was concern when digging the piles. Here's the bit: One dig found bedrock at a convenient depth (end friction) but not so the other, where side friction is relied on to support the deeper pile and all substructure on a questionably-stable river bottom. btw: Neither Robeling or government officials would have bet their bones that this American icon would be standing today, but it is.
    Can't imagine drilling with the PHD and not working the throttle continuously, backing off a bit (rpm) when lifting to clear each 'peck' or givin' 'er more when going in to prevent stalling as needed. I've 'drilled' dozens with an 'Earthquake' hand-held auger for every one done with tractor power, and obviously a helper to muscle auger & extension when pecking-in/out. If we get a rhythm going, 3 rotations then lift a foot or so, seems to clear best in all soils (sand or clay here, pick one, plenty of rocks everywhere in the GL basin) without rattling loose soil to fall back or over-widening the top of the hole. I'm convinced that moderation will allow some compaction in the sides vs wobbling a crater, and bet the OP got a feel for that by the 3rd or 4th hole.
    Sleuth, I'd also bet the next six holes you dig take half the effort of the first few. (You go, man!) btw, guys: I never asked my 'rebar' guy about heavy mesh like that. Is that where to look for it, or is it 'ag' stuff that TSC or someone would offer?
  6. #36
    Join Date
    Mar 2002
    Posts
    52,455
    Central florida
    yup. adding a side load to a pile really makes it grab!
    souNdguy
  7. #37
    Join Date
    Mar 2014
    Posts
    95
    Blanchester, OH
    1959 Ford 881
    Updated photos...
    Had to go out and buy a grommet kit and elastic straps today. My tarps are over-sized and I need to trim them down. Then have to build the rear window shutter and cover the tarps in chicken wire. Need to back-fill in the spaces around the base. Then sand & gravel on the floor, followed by a bunch of pavers I have laying around. Also need to build roosts and nest boxes.
    Going to have to pause a couples weeks on a few of these steps as I've still got too much month at the end of the money.
    First time using PTO. Can I get a quick primer?-10176062_10152734750109409_2611192855819849404_n-jpg
    First time using PTO. Can I get a quick primer?-10269415_10152735523319409_4033348607860567417_n-jpg
    First time using PTO. Can I get a quick primer?-10152656_10152734749684409_1039505089436089603_n-jpg
    First time using PTO. Can I get a quick primer?-1902934_10152735542239409_8354555799740568505_n-jpg
  8. #38
    Gold Member Kirk-NJ's Avatar
    Join Date
    Sep 2009
    Posts
    355
    Are you sure you have enough ventilation for the hot months? Do the sides roll up? Are you planning to bluid a pen outside for the birds?
    Kirk
  9. #39
    Join Date
    Mar 2014
    Posts
    95
    Blanchester, OH
    1959 Ford 881
    Quote Originally Posted by Kirk-NJ View Post
    Kirk
    I am undecided yet on building a pen or free-ranging them. If I don't build a pen, I have to fence in my garden.
    As far as ventilation goes, this thing is in the shade during the hot months and besides it leaks like a sieve all the way around. The birds were cold last night - all huddled in a corner - so I had to put in heat lamps and break a bale of straw for them. I walked outside and there were all kinds of draft sources lit up. I'm going to have a lot of work to do to get it ready for winter.
    I have ventilation at the top of the arch on both ends. I have a larger window on the back wall. I could remove the glass from the front door and replace it with open windows. Do not plan on rolling up the sides.
  10. #40
    Join Date
    Mar 2002
    Posts
    52,455
    Central florida
    tip. birds like to roost too.. give them some roosting spots. keep their foot size in mind for comfort. and don't use metal pole. it gets cold and hot.
    souNdguy
Similar Threads
  1. primer drying
    By ugabulldog in forum Customization
    Last Post: 09-03-2011, 02:20 PM
  2. Kubota Hour Meter-Real Time or PTO Time
    By GuyL in forum Kubota Owning/Operating
    Last Post: 07-18-2006, 11:12 PM
  3. Water over the dam, time for quick action
    By PineRidge in forum Rural Living
    Last Post: 04-20-2006, 10:42 PM
  4. Quick BX23 ?: Hoe and MMM on at the same time?
    By Spudgunner in forum Kubota Owning/Operating
    Last Post: 05-15-2005, 07:21 PM
  5. When is a 540 PTO at 540? PTO primer needed
    By Electron8 in forum Kubota Owning/Operating
    Last Post: 03-10-2005, 06:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
