Results 1 to 8 of 8
  1. #1
    New Member
    Join Date
    Dec 2012
    Posts
    23
    Ga
    Ford 8N
    Default Is this a 6 loop rim?
    My old 8N has larger than stock tires on the back. It currently has 12.4x28.
    I was looking at Tucker Tire to order a new tire and tube already mounted to a 6 loop rim, but not sure it will fit.
    Is this a 6 loop rim? It does not look like others I have seen pics of online.
    -img_2981b-jpg
  2. #2
    Super Star Member Egon's Avatar
    Join Date
    Aug 2001
    Posts
    17,521
    Nova Scotia, Canada
    Default Re: Is this a 6 loop rim?
    Not sure of your terminology but the rim shown has eight studs.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  3. #3
    Silver Member bg71361's Avatar
    Join Date
    Feb 2006
    Posts
    111
    Damascus, Maryland
    Yes a 6 loop would be a replacement rim for the 24" 6 loop to be exact. What is pictured is an original rim from a 8N.
  4. #4
    New Member
    Join Date
    Dec 2012
    Posts
    23
    Ga
    Ford 8N
    Cool! I thought these might be original (or at least period original) wheels from the 40's-50's. I did not notice the difference between these and the 6 loop rims until I started looking today and was not sure if a new one would fit the centers that I have.
    Just found a local tire shop that would replace the tire and tube for $350, so I'll be keeping my originals!
    Thanks.
  5. #5
    Super Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    9,985
    Central Ohio
    Kubota l3400
    Yep that is a period original "hat" style rim.
    If your rims are good though, no point in buying more. Cheaper to just replace tube and tire as you are doing.
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    Ford 5500 Backhoe
    Kubota L3400GST W/LA463 FEL
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #6
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    47,245
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    as said.. that is a hat rim. hat centers will bolt to 6 loop rims , if needed.
    souNdguy
    sent from my NOKIA LUMIA
  7. #7
    Join Date
    Mar 2002
    Posts
    47,245
    Central florida
    Quote Originally Posted by Egon View Post
    lugnut studs has no bearing on the rim to center attachment. that is a hat rim.. a 28" 6 loop rim will mate to an original hat style center.
    Quote Originally Posted by bg71361 View Post
    that's a 28"er
    souNdguy
  8. #8
    Join Date
    Feb 2006
    Posts
    111
    Damascus, Maryland
    I stand corrected 28" it is!
Similar Threads
  1. Tiger Loop on furnace
    By wjmst in forum Rural Living
    Last Post: 01-25-2013, 11:52 AM
  2. geothermal pond loop?
    By 20 20 in forum Projects
    Last Post: 03-26-2011, 12:50 PM
  3. Out Of The Loop!
    By jayste in forum News/Feedback
    Last Post: 04-01-2010, 03:47 PM
  4. b3200 hydraulic loop?
    By NH-Rob in forum Kubota Owning/Operating
    Last Post: 07-02-2009, 01:09 PM
  5. closed loop...really?
    By marrt in forum Power Trac
    Last Post: 11-11-2008, 12:54 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
