Results 1 to 7 of 7
  1. #1
    New Member
    Join Date
    May 2015
    Posts
    4
    East Bethel, MN
    1953 Ford Jubilee
    Default Jubilee steering lubrication
    On the naa tractors I noticed reading the lubrication and maintenance that there is a place to add gear lube for the steering assembly. I looked inside the hood area and found what looked like a plug on the right side of tractor. It looked like maybe a quarter inch plug.
    Is this where you add oil? If so do you fill it to where it is level with the plug?
  2. #2
    New Member
    Join Date
    May 2015
    Posts
    4
    East Bethel, MN
    1953 Ford Jubilee
    Default Re: Jubilee steering lubrication
    Soundguy. I was hoping you could respond to my question here. Searching threads on here you really know quite a bit about these ford tractors.
  3. #3
    Epic Contributor Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    49,263
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    right side of tractor? that doesn't sound like the steering box to me!
    the steering box is in 2 basic pieces. a cast body and a tube top column with a small cast base. the tube top with small base sets atop the main steering box body. that cast top has a plug in it, remov ethat plug and fill with lube.
    Original lube was gear oil ( or heavy 50w motor oil ). if the sector seals leak, the gear oil will leak out. You can put in nlgi #00 grease ( many mower shops sell it in a quart squeezy tube bottle ). Ford went the 'thin grease' route in 1962 with a service bulletin.
    Some people just remove the plug and put in a large grease zerk fitting so they can pump the grease in there. pumping it in, lets you not only fill the lower csavity, but lets you pump the steering column full till it extrudes out under the steering wheel a bit. then you know all 3 bearings are lubed.
    souNdguy
    sent from my NOKIA LUMIA
  4. #4
    Join Date
    Mar 2002
    Posts
    49,263
    Central florida
    -3-jpg-2-jpg-1-jpg
    here is a pic of a ford 2000 steering box, it is VERY similar to the naa steering box. see where there is a grease zerk i circled in red. that used to be a plug. your naa will be 'close'
    souNdguy
  5. #5
    New Member
    Join Date
    May 2015
    Posts
    4
    East Bethel, MN
    1953 Ford Jubilee
    Ok thanks. I should of said right side of upper top half of steering assembly. It does look basically like yours. If I put a zerk on it seems like I could just use any wheel bearing grease then?
    When you say sectors do you mean the arms that come out of the steering assembly and connect to the pitman arms?
    If so looks like there is some oil leaking a little down on the bottom of the steering assembly.
  6. #6
    New Member
    Join Date
    May 2015
    Posts
    4
    East Bethel, MN
    1953 Ford Jubilee
    Or should I look for #00 grease for a grease gun. I will look for some.
  7. #7
    Join Date
    Mar 2002
    Posts
    49,263
    Central florida
    Sector shaft has sector arms.
    Don't use #2 grease, it will cavitate. You can buy #0 grease un tubes, ir manually load your gun with 00 from the squeeze bottle.
    souNdguy
Similar Threads
  1. Power steering for Ford jubilee
    By Mood in forum Customization
    Last Post: 09-16-2014, 12:41 AM
  2. jubilee steering adjustments
    By donet in forum Parts/Repairs
    Last Post: 01-27-2012, 08:56 PM
  3. jubilee steering wheel removal
    By Foxstangs in forum Ford Vintage Tractors
    Last Post: 07-17-2010, 04:22 PM
  4. Grading Steering Box Lubrication/Maintenance
    By Tom_Veatch in forum Yanmar
    Last Post: 10-04-2006, 10:13 AM
  5. Jubilee Steering Box Surgery
    By Kendog in forum General Vintage Tractors
    Last Post: 05-05-2005, 10:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
