MarlinSlayer
So I'm underneath the tractor and I see these four bolts just aft of the flange where the engine bolts to the transmission. They are on a flat part of the casting going athwartship (Side to side for you tractor types). I'm missing a bolt and nothing is leaking out, so I assume they are a mounting point for optional equipment. There are similar ones underneath the rear end. Am I correct or is it something else. I have tried to find exploded views, but none of the diagrams show these.
[URL=http://s998.photobucket.com/user/wtss1/media/IMG_0959_zpsaaxf1why.jpg.html][/URL]
You may wonder why a mechanical neophyte might buy an old tractor.....well, it is to cut and manipulate the fields on my little slice of heaven to experience this with my boy.....his first.
By the way Soundguy....I understand the electrical speak....as you see I was trained in electrical engineering. I had to see the wiring diagram of inside the alternator to get what you were saying.
Thanks for all the help guys....with your help...I'll get thru this.
