ah64driver2002
Hello everyone. New to the forum looking for some onsight. I have a ford 3000 gas tractor that I have recentlyrebuilt the engine on due to spinning a piston on the crankshaft a while back. The crank was repaired. New sleeves installed in the block and numerous other parts replaced during the rebuild. After some minor set backs and multiple tractor splits the tractor is back together. On the initial start the oil pressure light remained on. So i thought maybe the sensor was bad so i replaced with a gauge. And to my dismay the oil pressure gauge sat between 0-1 psi. So i thought maybe yhe pump went out( I am unsure as to what caused the initial failure of the engine). So i purchased a new pump. Primed and installed. Cranked engine an no pressure. I am kind of at a loss for what the issue might be but i was given an idea to take a garden sprayer filled with oil and attach where i connect the psi gauge. Droping the oil pan and pump the oil back thru that port and see where the oil comes back from. Any other ideas or troubleshooting i should try. I appreciate any help on this issue.
