kuschneider
Here is a 1963 Ford 4000 S-o-S. My buddy and I are getting this from a co-worker of his in exchange for some labor around her place, and possibly a little cash. We were at $650 for the tractor, brush hog, and blade. Then she started listing stuff she would like us to do in exchange, so the out of pocket expense keeps going down, which is good.
Here is what we know.
Hasn't run in several years
Has a 6V generator, but a 12V ignition coil, and 12 v battery from walmart
Oil was full, dirty, but no sign of water
Radiator has clear, green coolant.
Was gas in tank, needs to be removed and cleaned
Got sediment bowl off and cleaned. Screen, gaskets on the way
Rebuild kit for carb on the way.
Going to need an air cleaner
Serial Number is 23450
Model 41105
Tires are pretty rough, but hold air
Sheet metal has a lot of rust, gonna be a bear to get off to remove tank.
I have an external gas tank that I threw together to test with to get it running.
Look forward to getting in back in action and working. I have a small place, 20 acres, that I hunt on, and the tractor will be use mainly for brush hogging, discing, and general tasks around the place.
Thanks in advance for any help.
Model 41105
