kuschneider
OK,
I am trying to figure out why my tractor will not crank via the push to start button. Here is what I know and have done.
Yes the tractor Runs. I hot wire the tractor from a battery + to the ignition coil and starter nut, and batter (-) tractor frame and it starts
The push button switch has continuity. My toggle switch was bad, I just have those wired taped right now.
I have continuity everywhere I should ( I think). My gut tells me this is a lack of ground issue.
See my simplistic picture below. My starter will turn if I run a jumper between
1--> 4 (duh)
1-->3
2-->3
I was in the process of cleaning/tighenting all connections and the lower of the two smaller terminals on the starter solenoid busted. I know I need a new one, but I would like to know
a) was the current one already bad
b) what is the correct solenoid to order
3) OR is this not grounding because of the neutral safety switch?
1--> 4 (duh)
1-->3
2-->3
