cobalt650
Member
I went "Up North" to cut some grass with our 1953 Ford NAA. It has a gas shut off valve, and is only filled with Ethanol free Premium with Sea Foam. It hadn't been started in a few months. Started well, but I had to keep the choke out to keep it running. Cranked up the idle, was able to cut some grass. Then it would only sputter, with the choke full out. Quit if the choke was in. Not sure the nuts/bolts will survive if I pop the 65 year old carb off. Think I could spray some carb cleaner in the main jet screw opening? Or maybe just buy a new carb and swap it out? Time is at a premium, it is located 4 hours from home in Northern Wisconsin. Thanks much,
Steve
Steve
