billbill1
- Joined
- Oct 13, 2004
- Messages
- 1,180
- Location
- Lecompton, Kansas
- Tractor
- 2016 Mahindra 1533 Shuttle AgKing 2840 shuttle shift
I read some before posting, a friend of mine brought me his 8N to work on. At first, there was no spark, removed the points (new) filed them some and reinstalled. I ran a compression test on all four cylinders and each one has 120 lbs. of compression. It has a brand new coil, has been converted to 12 volt. At first, on the distributor side of the coil, I had constant 12 volt, now it goes on and off as it passes each lobe. It was rebuilt several years ago and the engine is completely spotless. Machine is in very good condition, very clean. My buddy says he could always get it to start by pulling it but has always had problems starting from the starter. He loaned the tractor to a friend of his and it hasn't ran since. I told him to bring it by and I would try and get it going for him. He also told me that it has always burnt the points since he has had it. He is willing to buy a pointless ignition or anything it needs to get it right. I looked online at the pointless ignition and found them for around $85, are they better than the regular point system? I haven't checked the timing yet. I pulled the carb (also new) and it had a small amount of water in the bottom, i cleaned that up and the carb to manifold gasket was shot so I made a new one. He replaced the sediment bowl, it leaks and will need replaced again, I can't get it to stop leaking at the bowl and the rubber gasket looks OK. It spins over fine but doesn't try to fire. I know lots of you guys know all about these tractors and I'm wondering what to do next. Don't want to start throwing money at it until I get it firing at least. Thanks in advance for your help. Each plug is firing but the spark seems weak to me but I know nothing about these little machines.
