thompsonseatgrinder
Member
- Joined
- Feb 18, 2013
- Messages
- 40
- Location
- Carrollton, OH
- Tractor
- JD 318, Case 680C backhoe, JD 850 4wd, Cat D2 dozer, gravely L
I'm having problems trying to get an 8n to charge. I am on my 3rd. new voltage regulator (Tisco). After installing the new VR, it will charge as it should for about 3 minutes and then the amp gauge will fluctuate on the charge side for awhile. The voltage will rise to about 7.2 and then the amp's (amp gauge)will drop back to "0". If I ground the regulator terminal, it will show charge again but only until then. If I shut the motor off and restart it won't charge until I ground the regulator terminal. This is a total restoration and everything is new on the charging system except the generator(which was gone over and is charging) Any thoughts? Thanks
