goatman860
I just picked up up a wagner loader for my 860. I believe it is a power loader, but am unsure of the model and specs.
The backstory-
My 860 had a loader on it in a previous life, so the 10 spline adapter is still mounted on the crank pully. The center axle was also cracked/welded decades ago towards the left side assembly.
My first problem is when I pulled the bumper off and looked through the pin assembly where the pump driveshaft would go. The adapter plate is sitting lower than the opening, not allowing the shaft a straight shot to the future pump location. So much in fact that I could not even slide the shaft into the crank pully adapter plate to test fit.
Looking at the tractor manual the only thing I can think of is the bushing is shot, or the pin or support assembly is bent or crooked?
I believe I have a non threaded pin assembly looking at the picture in the manual. When taking the bolt out of the bottom of it it just twisted off with no force as well.
While I would like to restore this tractor someday, it is my sole workhorse for now, and I dont know if this loader is even viable.
Any advise would be great for the loader info, missalignment of the axle assembly, what the likely culprit is, and what has to be done. Also if needed, how to pull the pin assembly. The manual just says use a slide hammer with a suitable adapter.
Thank you
The backstory-
Thank you
