Fred Bear
Member
- Joined
- Mar 30, 2018
- Messages
- 29
- Location
- Richmond, mi
- Tractor
- Ford baby 8n, 821 Powermaster and NH TC-18
Hi all, new to the site. After sitting all winter up here in michigan I notice a big pool of hydrolic oil pooled under my tractor. It痴 coming out of a cover plate on the bellhousing. The weep hole pin is not in place anymore which I didn稚 know was a thing until reasearching this issue. I took the plate off and it痴 drainging the oil water and sludge. Just to double check this area should be completely dry correct? Do I have a bad shaft seal/bearing leaking into this area from the trans?
